Old 08-29-2018, 06:55 PM   #1
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
Door windows
Is there a website that is good to find door windows? Or, junkyard time!
mikeypj is offline   Reply With Quote
Old 08-30-2018, 11:02 AM   #2
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
Are the windows the same size as the windows in the front and back at the top? I deleted those so I have one. I broke one. Seems like it's close to the same size?
2martins is offline   Reply With Quote
Old 08-30-2018, 04:49 PM   #3
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
Its roughly 12"x25.5"
Old 08-30-2018, 07:14 PM   #4
Chassis: 3000RE
That's almost the size of half of one of the windows. I wonder if you could make that work?
Old 08-30-2018, 07:56 PM   #5
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
I'd probably break it trying to cut it..is it automotive glass?
Old 08-30-2018, 10:22 PM   #6
Chassis: 3000RE
You can't cut tempered glass. You'd have to adjust the size of the opening or the gasket. The windows are tempered. They are not as thick as the door, windshield and upper window glass. That stuff is about 1/4"
Old 08-31-2018, 05:13 AM   #7
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
So im wondering if i could use like lexan as a substitute. Its the inside pane.
Old 08-31-2018, 10:50 AM   #8
Are your existing windows double pane and can you remove just the inner pane? If so then Lexan would be fine, it won't crack or break.
Old 08-31-2018, 03:50 PM   #9
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
Yup double paned. Its the inner pane..what and where can i pick up the rubber gasket that goes around the window? I need to replace it on every window..
Old 09-08-2018, 10:39 PM   #10
Dana's Avatar
Rated Cap: 36 adults
Our bus doors had broken glass and they were rusty. We found a new set with zero rust and perfect glass in a salvage yard.
We had the windshield glass replaced by a RV glass company, When he was doing that he said he could do the doors as well, but by then we have the replacement door, we just had not installed them yet.
But our glass was not double pane, just regular auto glass.
https://thebusabides.com/upgrades/shut-the-front-door/
Dana is offline   Reply With Quote
