Old 04-24-2008, 09:13 PM   #1
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
DT 360 oil capacity
Can anyone tell me roughly how much oil I'll need to change the oil on my DT360? This is without a filter change.
Thanks!
Sean
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 04-24-2008, 10:12 PM   #2
Engine: 7.3 diesel
Re: DT 360 oil capacity
I don't have that motor myself but I would guess it to be between 15 to 17 quarts.
Old 04-25-2008, 06:19 AM   #3
lapeer20m's Avatar
good guess. Mine held about 4 gallons, including the filters.
you are planning to change the filters aren't you?
The dt360 is the only skoolie motor i've ever had that didn't burn, leak or otherwise loose any oil. That was an awesome motor, especially after i turned up the rpm's and the hp.
Old 04-25-2008, 08:24 AM   #4
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Thank you for the replies. This will be an oil-only change.
Cheers!
Sean
Old 04-25-2008, 03:25 PM   #5
lapeer20m's Avatar
it's your bus, but i think it's a worthwhile investment to install a pair of $12.00 oil filters while your going through the trouble of changing the oil, or are you using some sort of special super filter ??
Old 04-25-2008, 03:38 PM   #6
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
No super filter but we only put a couple of thousand miles on the bus every year, so the oil is due mostly because of age, not really miles.
Mostly we're in a time crunch right now. If I can squeeze it in, I'll do the filters as well. Thanks for the prodding.
Sean
Old 05-03-2008, 06:38 PM   #7
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
I was able to change the filters too. About 18 quarts is what she took.
Thanks
Sean
Whats the oil capacity of my bus? Spoon International | Navistar Drivetrain 7 03-18-2019 08:24 AM
Capacity and Bus Dimensions Seeria Conversion General Discussions 7 08-29-2017 05:22 PM
Tank capacity? porkchopsandwiches Plumbing, Water and Waste 3 12-12-2013 04:17 PM
Tow capacity of a school bus? stonestatue Everything Else | General Skoolie Discussions 3 09-15-2012 12:21 PM
Overall WVO capacity recycler Veggie Oil | WVO | Biodiesel | SVO 6 05-20-2009 09:50 AM
