Old 05-14-2007, 09:03 PM   #1
GoneCamping's Avatar
While I don't have a direct answer to your question, I can tell you this much... smoke (or steam) coming out of the motor at any time in any place is NOT normal... I'd be VERY cautious of this bus...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 05-17-2007, 11:46 PM   #2
I am fairly certain that is normal behavior. My semi has done that from the day I got it (new). 270,000 miles on it now and no major problems yet!
letz4wheel is offline   Reply With Quote
Old 05-18-2007, 12:24 PM   #3
swinada's Avatar
white smoke? As far as I know white never indicates oil smoke, oil would be black / blueish.
White normaly stands for something waterbased, coolant or just moister build up from sitting around.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
https://picasaweb.google.com/swinada/BusPictures https://www.swinada.com/bus.htm
https://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Dog Nose vs. front engine vs. rear engine? dgorila1 Conversion General Discussions 20 12-21-2011 06:40 PM
Engine oil capacity for 1986 DT466? crazycal International | Navistar Drivetrain 2 05-23-2010 02:18 PM
DT466 engine oil capacity. crazycal Mechanical and Drivetrains 1 05-21-2010 03:45 PM
Well the winds came up and began to blow frank-id Everything Else | General Skoolie Discussions 6 04-20-2008 10:32 AM
Handling a tire blow-out w1bmw Everything Else | General Skoolie Discussions 3 10-25-2006 09:28 AM
