11-10-2018, 09:04 PM
DT466/MT653 Combo?
Hello all,
Does anyone know what, if any, front engine flat nose bus came with a dt466 and an MT653? Also, for those with the front engine, how bad is access when doing a full rebuild?
Thanks!
11-11-2018, 03:11 AM
Originally Posted by revision
Hello all,
Thanks!
From what I understand the 653 is just a 643 with an extra gear thats a granny low 1st.
I've seen plenty of buses with 643's. If the extra gear were an OD it would be cool but even the CO buses don't need a granny gear so I'd never have any use for one.
11-11-2018, 08:31 AM
Thanks for that, I meant to say the 643! I forgot about the extra being granny, I just keep seeing combos with the 545 which I (perhaps mistakenly) believe to be less than desirable. Thanks for your input!
11-11-2018, 02:06 PM
The 545 is ok for in town and rural areas with speeds up to about 45. Its definitely not a desirable transmission. On a good day it could be called adequate.
11-11-2018, 02:40 PM
Thank you, I appreciate that.
I am inclined towards the DT..what would be the ideal transmission for long highways hauls and up and down mountains?
Is there a particular bus model that said combo came in and we should be looking for?
We are inclined towards FE transit style buses at the moment, and I would prefer '02 or older, but am open to suggestions. Thanks for the comments!
11-11-2018, 04:34 PM
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
I have dt466e with an allison 3060. 5 speed. Great for the highway.
11-11-2018, 04:53 PM
@pirate make/model? I took a look at your started threads and can tell you have a '98 international, but that's it. Thanks for the input.
11-11-2018, 06:11 PM
Coachwork: myself
Chassis: amtran
Sorry it's hard to update that on a phone.
98 int. Dt466e with an allison md3060
Its in an amtran 40 footer. Push
11-17-2018, 06:04 PM
Engine: DTA466
Rated Cap: 40 ish rugrats
I have an International 1993 with a tall headroom 35' dog house Thomas body. It has a fully mechanical DT466 and a 643 transmission. They are out there. Not a computer on the bus. Everything is mechanical
Thanks ..... Gregg
11-17-2018, 07:35 PM
they are definitely out there.. in fact anything before 1995. was generally 643 equipped if it had a DT466.. ive heard of some very isolated cases where a mechanical 466 had a 545. but its rare.. navistar didnt like to sell the 466 with. 545 even though it was often asked for..
once the 466E came out, a low torque variant was created and offered with a 545..
the 466 mechanical and 466E are different animals..
11-17-2018, 08:01 PM
Coachwork: Amtran Genesis
My 1993 Amtran Genesis has a fully mechanical DT466 engine backed by the MT643 transmission. Space for a rebuild on this bus would be limited. If doing an in frame build it could be done by removing the radiator and the inside doghouse.
I wanted a purely mechanical bus for ease of repair. You can bump the power up on them by adjusting fuel and timing.
I also wanted a front engine configuration in order to turn the rear into a toy hauler.
