Old 03-15-2019, 06:17 PM   #1
Dead pirate's Avatar
Chassis: amtran
Engine: international md 3060
Rated Cap: 13 ton or so says the tit
Dt466e alternator removal.
The pivot bolt that the alternator rests on is stuck. It won't rotate and won't pound out. Heat and pb blaster does nothing. Confused as to why it don't come out. Any ideas?
Dead pirate is offline   Reply With Quote
Old 03-15-2019, 06:26 PM   #2
if you remove the other brackets around the alternator will the whole alternator and bolt spin as one? im assuming you cant get an impact in there to bang on it?
Old 03-15-2019, 06:55 PM   #3
Johnny Mullet's Avatar
Engine: T444E 7.3L
The bolt is stuck in the steel sleeve or most likely the aluminum parts of the alternator. Find out what part it's stuck in and use some heat on the stuck section with a hand torch.
Mullet's Thunder Bus Build
Old 03-15-2019, 08:40 PM   #4
Chassis: amtran
I can remove the bracket below it (along with it) but that bolt will still be stuck. It's probably frozen in the sleeve. Or something. I've had a torch on it. 6' bar....5 lb. Sledge from behind.
Hope it doesn't go out anytime soon. Most likely leave it in. I like my 360 alternator.
Old 03-16-2019, 07:02 AM   #5
If you don’t have to yank it then id keep hitting it with PB every day or two.. that stuff works on over time, esp with heating and cooling like it will see when being driven.
Hristopher
Old 03-16-2019, 11:46 AM   #6
Chassis: amtran
Right on. That's what I'll do then. I can change it when i want.
Old 03-16-2019, 12:15 PM   #7
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
escalate the attack
Well, if the alternator is broken, then you cant break it. Right?
heat to the point the steel is glowing orange, drown the thing in penetrating oil. In the end you can cut the alternator off then work on the bolt.
Would you post some really up close pictures of the pivot bolt... and both ends of the bolt, especially then with the threads. Is the bolt going though a sleeve?
william
Old 03-16-2019, 12:27 PM   #8
Chassis: amtran
I'm at a kid birthday party. I will post tonight.
Old 03-16-2019, 06:03 PM   #9
Chassis: amtran
The bolt in question. The alternator pivots freely on that very bolt. 20190316_175831.jpeg20190316_175745.jpeg20190316_175731.jpeg20190316_175849.jpeg
