Old 09-09-2011, 05:00 PM   #1
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Dual Wheel Valve Stem Extensions
I am looking at putting some valve stem extensions on due the fact i have the hard metal stems that are practically not reachable!! I do not like traveling far without knowing the true conditions of my tires even though i hiked it a 1000 miles home without knowing previously.
I was thinking of ordering these... http://www.autoamenity.com/Wheel-Simula ... tender.htm
I think these would be a godsend and make it a heck of allot easier to check!
What is the opinion of the forum?
Old 09-09-2011, 05:42 PM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: Dual Wheel Valve Stem Extensions
Those are fine, for just a little more money you can have these
http://www.iowa80.com/DirectionsWEB/...ization+System
They come in different pressure ratings.
For a lot less money you can get these
http://www.iowa80.com/DirectionsWEB/...alve+Extensionor
http://www.iowa80.com/DirectionsWEB/...ion+5-1%2F8%22or
Old 09-09-2011, 06:28 PM   #3
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
i like that first one you linked. I need the lines to come out to the front so that would be the best. I assume there is a hook up there for adding air equally to the tires?
also 100 psi is a bit much for my rig
Foot valve Bavo76 Mechanical and Drivetrains 5 11-09-2011 12:09 AM
Dual ACs for the bus bapos Heating, Cooling and Appliances 18 06-08-2011 11:22 PM
valve stem seals on an 89 5.9 Jarlaxle Cummins Drivetrain 0 12-31-2010 10:47 AM
Top RPM for a cummings 5.9 24 valve engine funbus63 Cummins Drivetrain 5 12-19-2010 10:24 PM
EGR valve? hoser Everything Else | General Skoolie Discussions 4 07-08-2010 08:38 PM
