Old 09-18-2004, 09:12 PM   #1
lapeer20m's Avatar
eaton 13 speed
Eureka! I found an old ford 700 semi truck at the scrap yard with an eaton 13 speed in it for $250.
Currently I have a Ford B700 with a brazialian 6.6 liter and an allison auto with non lock up converter.
I'm not really sure how the 13 speed shift patern works? Anyone ever drive one of these crazy things?
Perhaps this trans will keep me happy enough that i won't have to sell my bus. Or perhaps i'll use this bus as a test vehicle to see how i like the 13 speed and transplanting it into a bus with a larger engine in the future.
thanks for your input
Wish me luck ! this is gonna be a big project
Old 09-18-2004, 09:30 PM   #2
The 13 speed is a 9 speed in reality. You shift the lower gears without using the splitter, and the upper gears you can or not use the splitter. The main reason for it was on a semi where when you go up a hill, you have an intermediate (and easier) gear to hit when you are downshifting. It should work killer in your bus. It will shift like a 4 speed -- start in low, then shift to high -- and split then if you want to. So its granny low, 1 thru 4, then high 5 thru 9 with intermediate shifts if wanted.
patarini is offline   Reply With Quote
Old 09-19-2004, 08:01 PM   #3
lapeer20m's Avatar
looks like i might have a buyer for my bus, so the trans swap is on hold until i find my "new" bus. I'll still buy the "new" trans and keep it at home until it's needed.
Here's my dilema. First off, I hate to spend money, but i want a bus with more engine than i have now. Ideally, a DT466 or a 9.0 liter. Those are hard to come by here in the flatlands of michigan.
I have to opportunity to purchase an international DT366 77 passenger carpenter very cheap from my local bus garage. It's the same place i got my current bus.
Do i purchase the cheap bus with an engine that is an upgrade from what i have now? Or do I hold out and keep searching for a bus with my dream engine?
Old 09-22-2004, 03:20 PM   #4
How bout buy this one, then buy the dream one! LOL -- You can always send one my way for storage!
Old 09-23-2004, 02:01 PM   #5
lapeer20m's Avatar
update: I found a bus with a 9.0 liter on ebay. I thought i really wanted a bus with that engine. After talking to Graig (he is the most knowledgable person i know when it comes to buses.) He said the 9.0 liter will keep running forever, but it actually makes less hp than the wimpy 6.6 liter already in my bus.
I guess about the only good engine left is the DT466, or the cat 3208.
How about transplanting an engine from a big truck? I've found two different cummins L10 (290-359 hp) that are for sale in big trucks for pretty cheap. I'd have to measure to see if it would fit.
This is getting entirely too complicated! and it's made worse by the fact that i'm very impatient.
IF I were giving advice to somebody else, I'd encourage them to wait until the bus they wanted came along.......and not to try to transplant an engine. But......Having a 300 horsepower cummings motor and a 13 speed trans would make a lot of skoolie owners envious!
With the proper rear end, the bus could go 100 mph! Not that I'd have reason to travel that speed in a bus.
Old 09-23-2004, 02:13 PM   #6
Steve's Avatar
I don't think you realize how large the big rig engines really are. When you get it out of the truck you will realize it's not even close to a big block auto engine.
Old 10-08-2004, 02:15 PM   #7
lapeer20m's Avatar
my brain thinks a lot, but my hands seem to not work nearly as fast. I want a bus that goes faster, i'm still not sure how to accomplish the goal.
I'm a very confused boy.
I looked at a big cummings motor on an engine stand next to a 6.6 liter ford. Steve is correct, the big truck motor is huge in comparison. It would require a bit of magic to get that to fit in a bus. not to mention the weight difference. that might require new suspension components and who knows what else.
After much consideration, i've decided that big engine swap is a not a good idea. Too much time money energy and effort required.
I've been talking to many people about the 13 speed trans swap including a rear axle swap at the same time. both are part of the donor truck. A couple of people who's opinion i value very much say changing from a auto trans to a manual is far more work than i realize, and is not worth the effort.
Old 10-08-2004, 02:28 PM   #8
lapeer20m's Avatar
here are some options:
1. for $300 bucks i can buy a auxilliary trans that will bolt up to the bus and work just like an overdrive. ~16% increase in gear ratio.
2. For $250 bucks, plus the tow truck fees, i can bring home a big F700 (7000?) semi truck with a 13 speed eaton, and most likely a very nice gear ratio in the rear end. 3.56 perhaps? I could do an entire trans and an axle swap. Or i could start small, and just do an axle swap to see how the bus will do utilizing the current allison auto trans.
3. I could keep searching and possibly find a 2 speed rear end for a couple hundred bucks.
I don't know what to do!
Old 01-21-2005, 05:52 PM   #9
lapeer20m's Avatar
well....it's been a lot of months and i'm still thinking about the eaton 13 speed.
I think that this spring when it warms up i'm going to bring home the donor truck that has the 13 speed and the better gear ratio rear axle and get to work on the project. There are a couple vairables that might make the trans not bolt up to the engine, but most people who seem to be in the know tell me that it should slide in without any problems.....except the driveshaft length.
If i could do the entire project for under $1,000 and make it work properly, total i'd be really happy.
to be continued.......
Old 01-21-2005, 10:15 PM   #10
Coachwork: Ward Genesis
Engine: DT466/MT643
I have to suggest runing away from the 9.0 IH as fast as you can. You're better off with a gas engine.
If memory serves, the 7.8 Ford diesel (I've seen them as high as 275HP) is a bolt-in to replace the 6.6 litre. Look for F-700's, -800's, & -900's and F- and L-7000/8000/9000's as donors.
Maybe a Cummins B-series? 350HP from one of them isn't even slightly difficult.
Jarlaxle
Old 01-22-2005, 10:10 PM   #11
lapeer20m's Avatar
For right now, i'm sticking with the 6.6 liter ford, just planning to swap transmissions. I'll see how this upgrade improves speed/power to the rear wheels.
Finding a 7.8 ford with 275 hp would be awsome! I looked at one here at the local school district that only had 10 hp more than my 6.6 liter.
Hope the trans swap goes without a hitch. I've never even separated an engine from it's transmission before. However, I'm mechanically inclined, and i've done a fair bit of fabricating.
Just waiting for the weather to get warmer. It's currently in the single digits and we're in the middle of a snowstorm.
Old 01-23-2005, 09:46 AM   #12
Engine: DT466/MT643
Still snowing lightly here...about 2', with car-high drifts.
For the high-HP 7.8 engines, look in 10-wheelers (F-900, L8000, L9000) & single-axle L8000/9000 semi tractors.
Good luck with the 13-speed.
Jarlaxle
Old 01-26-2005, 09:02 PM   #13
The other day we went to visit some friends and I saw a bunch of Laidlaw school buses. They were all rear engine International Amtran models. After doing some research on the web they have a DT466 in them and many are ordered with MT643s. Laidlaw their used buses so I doubt you could get a good deal like at auctions but it is a thought. I am sure somewhere some school district uses those buses and would auction them cheap. I am telling you about this because I remember somewhere you said you wanted a transit style skoolie.
busone is offline   Reply With Quote
Old 01-26-2005, 10:21 PM   #14
lapeer20m's Avatar
Thanks for the info. Realistically, i cold probably buy a new used bus with a bigger engine and a better trans as cheap as i could swap a 13 speed into my bus.
why don't i just do that??
I've done a fair bit of searching for buses around here, and have not been able to find a good engine/trans combination. I would love a DT466/643 snub nose bus. Next fall one of the local school districts around here are auctioning off some DT466/AT545 dog nosed buses. This year all they had were DT360's. The disadvantage to these buses is that they don't have air brakes. I need air!
After swapping the trans in my current bus, it should be quite a bit easier to do it to the next bus when/if i find one with a bigger engine.
I'm confused, and don't really know what is the best course of action. My options are open. Eventually my school district will get around to selling their buses. There are about 10 of them that are ready for auction. Most are carpenter bodied 72 pass internationals with dt360/at545. I've started all of them, they all sound good (one needs an exhaust though)One of them has a bad trans and doesn't move. The rest all run and drive. I'm sure these buses will go for cheap: $500.00 or less. The bus with a bad trans should go for almost free. The DT360 gets less mpg than my 6.6 liter, but it's a higher performance engine. That would be a good candidate for the 13 speed eaton. IF i put the manual trans in my current bus, it should be that much easier to swap it into the "new" bus at a later time. I'm not doing any crawling around under my bus until the weather warms up.
I guess the options are: A new bus with the right engine/trans, my current bus with a different trans, or a new bus with a better although not ideal engine and the new 13 speed trans. The latter two options are convienent. I've been looking for about 6 months for the bus i want, and have been unable to locate one that's in my price range. I don't like the idea of spending over 1,000 dollars for a used bus. It would have to be something pretty special. Realistically, if the bus had a DT466 and the lock up/overdrive allison auto it would be worth 2 grand.
I don't know...i'm just a confused boy!
Old 01-27-2005, 08:40 PM   #15
I know what you mean about trying to find the ideal bus. Are you willing to travel very far to find it? Have you checked out 422 sales? I have followed many of their auctions and some good buses go cheap. Just scroll down to the bottom of their homepage and you can see some of the previous auctions. It seems like a lot of carpenter buses are being dumped still. Some are forward control models with DT series engines in them. Just take your time and the right bus will come along.
Old 01-28-2005, 04:46 PM   #16
lapeer20m's Avatar
I dont' mind at all owning one of the carpenter buses.
It was so easy to find my first bus. I wasn't even looking, she just followed me home by accident. gotta love impulse buying!
Eaton 19050S gear ratio?? Henukaw GM | Chevrolet Drivetrain 8 02-23-2015 01:50 PM
Eaton 5spd info Diddly Mechanical and Drivetrains 1 05-20-2011 11:56 PM
Help: Eaton Axle Shaft Removal trx Conversion General Discussions 3 08-05-2009 08:00 AM
Eaton Rear axle lubricant reccomendations? JonCBrand Conversion General Discussions 1 07-13-2007 10:09 PM
1986 bluebird DT466/5 Speed man/2 speed rear code4 Classifieds | Buy, Sell, Swap 2 08-14-2006 11:29 PM
