Old 03-31-2016, 11:34 PM   #1
Year: 90
Chassis: international
Electric heat
I have really progressed in my build with all mechanical systems in and most of the interior.
I will be spending a lot of time plugged in so I,m thinking of adding electric heat.
Namely a couple of Pik a watt fan forced heaters. 750-2000 watts, These have enclosed elements instead if hot wires and mount in the wall.
I had one of these in my last trailer that worked very well. But I had it close to the floor and was reminded that propane is heavier than air and if a leak developed with the heater on... BOOM!
Has any one mounted these things up high like in the front and rear end caps?
Any input?
Old 04-01-2016, 08:11 AM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
The problem with that is cold air is heavier than warm so head would stay in the ceiling.
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
