Old 07-28-2015, 10:57 PM   #1
Zephod_beeblebrox2's Avatar
Year: 1994
Coachwork: carpenter
Chassis: international
Engine: 466dt
Rated Cap: 59
Electrical connections
I need to put an external power connection on my bus conversion. What kind of connector do I need in order to connect at campsites? Do I need a cable?
Zephod_beeblebrox2 is offline   Reply With Quote
Old 07-28-2015, 11:46 PM   #2
Chassis: Blue Bird
Engine: ISC 8.3
wikipedia NEMA connectors, see the chart under "NEMA nomenclature" If I was to rank them in order of most to least common campground connections, I'd do it like this: 5-15, TT-30, 5-20, 14-50. I don't mean to imply the 50 amp 14-50 is uncommon; it's actually fairly prevalent. But the others are even more so. Some campgrounds will charge more for a spot with the 14-50 connector because the person asking for it is likely to consume more electricity than the person using a 5-15 or TT-30. "Dogbone" adapters are available to down-convert most any combination (ie 14-50 on the RV down to TT-30 or 5-15 on the pedestal, TT-30 on the RV to 5-15 on the pedestal, etc).
The choice is up to you and depends mostly on how much power consumption capability you want to build in. From your other thread on fuses, it sounds as if even just a 15 amp (5-15 connector) might meet your need.
For cable.. there are lots of opinions. Mine is that a cheap home center extension cord is not an ideal choice because it's "junior" class cable and is easily damaged (if you read the codes printed/stamped on the jacket, you'll see SJ-something, probably SJTW, on its jacket). I prefer SOOW because the insulation is a nitrile rubber-PVC blend which is both more flexible and more durable. Many Home Depot locations sell it by the foot, but you'll probably get a better price at an electrical supply house. Both will have a cord end for whatever style plug you choose.
Old 07-29-2015, 10:40 AM   #3
I have a NEMA TT30 male on a 25 foot 10ga. cable. I plug into the 30a CG receptacle or a 4000w Onan on board.
If I need more cable I have a 20 foot 8 ga. with m/f TT30's.
Don and Mary
dond is offline   Reply With Quote
Old 07-30-2015, 07:29 PM   #4
Year: 1994
Engine: 466dt
Rated Cap: 59
I can get plugs and cable at Lowe's. How long do I need for a cable?
Old 07-30-2015, 10:45 PM   #5
Chassis: Blue Bird
Engine: ISC 8.3
Truth be told, I've used campground hookups very little. It seems to be quite common that RVs have their electrical emerging from the left rear corner, and I'd expect campground pedestals to be located near there, that it'd be easy to park near the pedestal, and that 10-15 feet of cable would be plenty. But I'd probably be wrong... Maybe there'll be times when one wants to be away from the pedestal to be positioned just so in the shade of a tree, or the pedestal is in a lousy place and the cord has to wrap half way around the bus.. who knows.
The approach described by dond -- moderate length cable attached, with an extension available -- sounds good. If I were to have the same 45 feet of cable, I might divide it differently: 20 or even 15 feet attached to the bus and the remainder in the extension cord, so that I'd have a little less cable to wrangle when the pedestal is near. If it turned out that the bus piece came up short too often, it and the extension piece could be swapped.
Old 07-30-2015, 10:48 PM   #6
Year: 1994
Engine: 466dt
Rated Cap: 59
I'm planning to plug into a straightforward 110v household socket initially. I think that's a 15a max?
Old 07-30-2015, 11:33 PM   #7
Chassis: Blue Bird
Engine: ISC 8.3
Right. The breaker/fuse might be 20 amps, but the socket itself will be rated for 15 amps.
Old 07-31-2015, 06:50 AM   #8
I would have a minimum of 25 ft of cord, some older csmpgrounds they are at the rear left corner, most state parks we have seen have them about mid way up the left side, rigs are a lot bigger than the 8 ft pop ups that were popular in the old days
since mine exits behind stop sign, I carry an extension cord also (50 amp) and have had to use it almost every time, especially if I can't stick the rear overhang out due to trees etc.
ETA: real good deals on ebay for rv cabling
Old 07-31-2015, 08:22 PM   #9
Year: 1994
Engine: 466dt
Rated Cap: 59
I could put sockets on all corners lol
Old 08-01-2015, 09:56 PM   #10
True 20-amp 120-volt plugs for high-current loads have the neutral turned 90° compared to the hot to prevent them from being inserted into receptacles wired to provide only 15 amps. But nearly everyone uses the parallel-blade 15-amp style for both capacities.
If the neutral looks like a "T" lying on its side, it is a 15/20 amp outlet that will take both types of plug.
Most electricians will wire all outlets with #12 wires on a 20-amp breaker, and then use a 15-amp receptacle because the devices are so inexpensive when compared to the dual amperage style.
Old 08-02-2015, 12:56 AM   #11
Chassis: Blue Bird
Engine: ISC 8.3
You're entirely correct about electricians using 15A receptacles on 20A circuits (because they're cheaper, and because the code tolerates it), and that misuse of the 15A connectors for 20A loads is not uncommon (even though it's a code violation).
The problem with routinely running 20 amps through a 15 amp receptacle is heat. We've all noticed that a plug may get warm during heavy use; this heat comes from the tiny amount of resistance between the spring contacts in the receptacle and the blades of the plug. Power dissipation varies with current squared; when current is 1.3 times over the rating (20 amps is 5 amps over the 15 amp rating) then power dissipation (the heating) is 1.69 times over the rating. Excess heat, ie more than the wipers were designed to handle, will cause their spring to relax. This becomes a cycle with deteriorating contact from weakened springs causing increased heating, which further weakens the springs.. heat may increase until eventually something melts and/or ignites. The heat often won't harm the blades of the plug; only the invisible springy pieces inside the receptacle are damaged.
There's my public service announcement: please don't make a habit of running 20 amps through a 15 amp connector! (on the same soapbox: if you have sockets where the phone charger literally falls out because the fit is so loose, please replace that poor worn-out socket ASAP! That too is a heat and fire hazard.)
Old 08-02-2015, 06:14 PM   #12
Year: 1994
Engine: 466dt
Rated Cap: 59
I've seen plenty Soviet sockets that need a chair to hold the plug in!
I think I'll put a 50a socket on the outside of the bus and 3 x 15A sockets inside, each fused to 15A. Somewhere I might also put a 50a fuss.
