Old 04-17-2007, 04:51 PM   #1
Electrical Converter Panel Installation
I need help with electrical...... I have installed a converter from an old slide in camper... I want to be sure it is charging my on board battery.
Kevin W.
1986 Chevy C60 Bluebird Conversion
kevbethw is offline   Reply With Quote
Old 04-17-2007, 10:20 PM   #2
the_experience03's Avatar
Easy solution...put a voltmeter on the battery terminals with it disconnected and then again with it connected. You should see a rise in voltage. I would be more concerned that it isn't overcharging, but that's a whole different box of worms.
Old 04-18-2007, 04:24 PM   #3
frank-id's Avatar
Converter
The difference between high dollar converters and old units is the voltage regulation. New units can be allowed to be connected for very long periods with no monitoring. Old units will make great amps and volts but, requardless of battery condition or state of charge, the voltage just keeps charging. The old converters can easily be controlled using a time clock. My converter is about 20 years old and works great. One very important tool for electrical work is having and using a digital multimeter. Frankj
Question about electrical panel SitkaConvert Short-Bus Conversion Projects 4 08-27-2014 02:21 PM
Electrical panel Soundman1 Conversion Tutorials and How-to's 1 07-18-2012 05:24 AM
My electrical AC/DC panel install <dialup beware> talk2cfs Conversion General Discussions 1 05-01-2008 09:11 AM
interlock panel on electrical system adamanderr Conversion General Discussions 0 04-07-2008 06:59 PM
new 12v installation nyrockingchairs Conversion General Discussions 2 05-10-2007 02:28 PM
