Old 07-07-2018, 09:59 AM   #1
Chassis: TC 2000
Engine warning light
Ok so I finally got the bus up and running and it's about 90% converted. I started it up and drove it to get emissions testing so it can get registered.
On the way over a light and buzzer pops on the exact light shows " ENG WRNG" . All temps looks good on gauges? I changed fuel filter, air filter, oil and oil filter. Still pops up
Not sure how to troubleshoot this.
www.shawntomskoolie.com
AZtom is offline   Reply With Quote
Old 07-07-2018, 10:12 AM   #2
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
three biggies
That come to mind right away.
engine oil pressure... low = stop the engine right now.
engine temperature watch and slow down over 220 over 230 stop it
exhaust temperatures over 1300 for more than ten seconds or so. down shift and slow down
william
Old 07-07-2018, 10:30 AM   #3
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Rated Cap: 16
If it is an electronically-controlled engine, get a scangauge-D or similar type scan tool (assuming you have a J1708 diagnostic coonnector). That will be allow you to see the engine data and it can give you the exact fault codes...
If it a mechanical engine - hopefully someone with more experience with those will chime in
johnbloem1974 is offline   Reply With Quote
Old 07-07-2018, 05:01 PM   #4
Chassis: TC 2000
It's the Cummins 5.9 12v so it's all mechanical. It starts at about 10 to 15 minutes into the ride. I'm watching the other gauges and I don't see anything overheating maybe there's a sensor out?
Old 07-07-2018, 05:40 PM   #5
Rivetboy's Avatar
Do you have a low coolant sensor? The sensor is usually located on the front top of the radiator. With the engine cold jump out the sensor and see if that lamp illuminates.
Rivetboy is offline   Reply With Quote
Old 07-07-2018, 06:25 PM   #6
Chassis: TC 2000
Would you help me locate it not sure where to start hereClick image for larger version
Old 07-07-2018, 06:42 PM   #7
Chassis: TC 2000
I drove it for a little while longer and the low coolant light comes on even though I know I just topped off the coolant so is this a known issue?
Old 07-07-2018, 09:02 PM   #8
Topping off the radiator does not necessarily mean it is full.
Leave the rad cap off and idle the engine.
Watch at the radiator cap and you will see air bubbles coming out of the system.
You may have a lot of air in there or very little but it could bring on your warning light if still low. Add your antifreeze mix slowly and when no more bubbles appear, put the rad cap back on and go for a drive for a while.
Fill the expansion tank too the full hot mark on it.
Your light might go off then or you might have a leak somewhere and loose the antifreeze.
Check it everyday to see how it goes till you see an improvement.
Old 07-07-2018, 09:04 PM   #9
2kool4skool's Avatar
Look on the engine side of the de-aeration tank Tom, it's black with 2 wires. Sometimes they fail or need cleaning.
Don, Mary and Spooky the cat.
Old 07-07-2018, 09:34 PM   #10
Chassis: TC 2000
Thanks guys I'll do both and see how it goes
Old 07-07-2018, 11:08 PM   #11
Rivetboy's Avatar
My 91 tc 2000 5.9 cummins at 545 has a procedure in the operators manual on filling the trans heat exchanger and bleeding it off back in to the radiator
