Old 07-03-2018, 11:11 AM   #1
thrifty1's Avatar
Engine: DTA360
Enlighten me on finish flooring pros and cons
Iíve been looking at quite a few conversions but canít seem to make a decision on final flooring on top of the subfloor. Looking at splash guard t&g vinyl planks, but has anyone done sheet vinyl? Or even plywood?
thrifty1 is offline   Reply With Quote
Old 07-03-2018, 12:21 PM   #2
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
In my limited experience, most house flooring products will work. The possible complication is your environment. For example; I've heard that some laminate does not like lots of humidity (I don't have a complete list).
I've used laminate, carpet, vinyl sheet, tile, etc. They've all worked fine for me.
The details of the vinyl sheet install on my first motorhome is here: RV Flooring Replacement - JdFinley.com
JD - Full timer out west
My Adventures & Build
Old 07-03-2018, 12:30 PM   #3
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
I used polyvinyl sheet flooring like you see used in high-end garage floors.
Old 07-03-2018, 01:31 PM   #4
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
Roll vinyl will work fine. My dad owned a flooring company I worked at all through school.
If you go with roll, fix all your seams in ply or what ever your sub floor is and fill in nicks and cracks with subfloor patch or you will see/feel anything underneath down the road
Any questions you have on flooring I don't know I can run passed my dad, but he's been out of it awhile so he's not super up to date on new product.
PS sorry I missed you when I was in the neighborhood, rough weekend.
Whatthefak is offline   Reply With Quote
Old 07-03-2018, 01:33 PM   #5
thrifty1's Avatar
Engine: DTA360
Haha sounded like it. I saw you went to tri state and they treated you well, I plan on taking my bus over there when ready for a check up so thanks for sharing that.
Old 07-03-2018, 01:59 PM   #6
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
Yeah man they did me good, didn't try to get extra money upselling me and actually knocked my final bill down. Little stuff like instead of changing my fuel filters and selling me some spares he got me the spares made sure I had a filter wrench. Even called the next day to make sure everything was running good.
I'd go there again
Old 07-04-2018, 12:57 PM   #7
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
What do you use for subfloor patch?;
2martins is offline   Reply With Quote
Old 07-04-2018, 01:14 PM   #8
Chassis: 3000RE
As for flooring, I went with calibamboo's pro series LVP luxury vinyl plank because the specs said it could withstand the widest range of temps and humidity of anything I could find. I have no installed it yet. I need to frame the front edge of the floor, lay the last piece of subfloor and then do whatever I am supposed to do for the joints/ tiny cracks. Also, I left a gap along the edge for expansion. Do I put backer rod in there so it doesn't move but CAN expand? I want to have a floating floor *and* subfloor. Is that insane? Am I supposed to only have one or the other floating?
And what do I use for the joints before installing the flooring?
Old 07-04-2018, 01:50 PM   #9
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
I'm not sure on the brand of patch we used it's a powder you mix with water but it's kind of brittle, for a bus I'd just use the same glue you are using for the roll vinyl. My plan is to use two layers of thinner ply and stagger the joints and staple both layers together of one large bus shaped platform floating on foam board then plank flooring floating on that. I may use small L bracket to hold the ply at the walls if I have to much play.
Just be careful to leave room around the edge for expansion so your floor won't bow. A little kick board trim will hide it all.
