09-23-2019, 10:48 AM
#21
Originally Posted by Native
It does feel great to get that elusive part freed up!
Any pictures of the tacking & cutting you'd like to share?
This is the section that connects to the turbo, with the tacks, and the weld.
It was my first time welding exhaust, but I think it turned out ok. I'm gonna paint it with exhaust paint and then wrap it with heat "tape".
I'll put up a video on my you tube channel eventually. I have about five videos to edit before getting to this subject.
09-23-2019, 09:28 PM
#22
Instead of a flex tube, have you considered an elbow and a reducer? Ogburn Truck Parts here in Fort Worth carries all sorts of exhaust parts. Perhaps you have a similar company.
09-23-2019, 10:06 PM
#23
I already welded up an elbow, and have another one for the muffler. I want the flex pipe to absorb some of the vibrations and movement.
Something like this:
https://www.amazon.com/dp/B01FG9EDPC...ing=UTF8&psc=1
09-24-2019, 01:36 AM
#24
Originally Posted by Joe45
Yeah, the exhaust pipes are usually hung from rubber mounts which allow the pipe to move a lot. Your use of the flex pipe would help the flexing. I believe Cadilackkid suggested a rubber mount for the muffler. The two should help one another keep the vibration down.
09-24-2019, 02:03 AM
#25
Coachwork: Blue bird
Chassis: All American RE
Engine: 8.3L Cummins 6CTA
I recently removed my DPF and was able to re-utilize the existing pipe to make my own stack. Worked out perfectly as I will be towing my CRV and preferred not to recolor it black. I still have an extra 18" straight pipe if and when I do my roof raise. The original piping did not have rubber mounts, only 2 flex pipes and metal "U" bolts to support. I reused 2 U bolts for support on the stack and have not had any issues with vibrations.
09-24-2019, 11:28 AM
#26
The muffler will be solidly mounted to the side of the bus, since it will have the stack rising out of it, with the flex pipe taking the vibrations.
It''s a very short distance from the turbo to the muffler: maybe 30". I am planning on using a long flex pipe to make it extra pliant.
09-24-2019, 01:45 PM
#27
Engine: Cummins 8.3L ISC w/CAPS
Joe45,
If you have an air chisel, give the v-clamp a couple taps to free it from the collars. It should pop loose with a "blurp" or two.
09-24-2019, 02:15 PM
#28
Originally Posted by Audeamus18
Joe45,
Came loose with a couple of taps with a ratchet extension.
Thanks!
09-25-2021, 08:08 AM
#29
Year: 2005
Chassis: FS65
Engine: Mercedes 6.4L
Rated Cap: just the 2 of us
I know this thread is from 2019...I'm looking for pics of where people rerouted the exhaust out the side of the bus. When I measured for my waste water tanks, I didn't pay close enough attention...my gray water tank is supposed to mount over the tail pipe, I missed the 2 exhaust hangers that are in the way. Trying to decide if I should run the exhaust out in front of or just behind the right side duals.
09-25-2021, 08:25 AM
#30
On my Wanderlodge the generator and engine exhaust come out right in front of the drivers side rear tires.
09-25-2021, 09:53 AM
#31
Year: 2005
Chassis: FS65
how far beyond the body should I run the pipe? Should I be concerned about heat on the tires?
09-25-2021, 10:08 AM
#32
Mine's just turned out and flush with the body more or less.
heat shouldn't be a concern unless you've got the pipe right on the tire.
09-25-2021, 10:16 AM
#33
not sure about your bus but my TC has options.
check out the autojet catalog. i got the factory parts to turn my exhaust out to the side.
https://www.auto-jet.com/school-bus
09-25-2021, 10:33 AM
#34
Just behind the rear axle the exhaust pipe dropped down at a 45* angle and then another 45* angle to direct it out the back below the bumper. After carefully viewing I saw I could cut make one cut between the angle and turn the piece 90* to turn it out the side. Cut 5' of length off and brought it out the side a few feet behind the rear wheel.
