Old 07-18-2016, 02:20 AM   #11
Chassis: IH
The tires we run on these buses are engineered with an *ENORMOUS* safety factor. Granted, split rims aren't without their risks, but once safely mounted on a bus, the likelihood of anything happening during a routine tire pressure check is extremely unlikely. Same holds true for the tires themselves. If one is likely to fail, it is likely to do so upon its first inflation.
These are designed to withstand high pressures, a tremendous amount of beating from rough roads, hot pavement, frigid conditions, and countless other factors. So checking pressures while at rest is not likely to cause a sudden rupture.
Old 07-18-2016, 03:29 AM   #12
Manufacturers would get sued for big $ if their products were so unsafe that an end user could be seriously injured doing standard user checks.
Yes when the tech is doing a change there are risks but that's why you pay them to use their safety gear.
What gets difficult is writing the owners manual as the second stage manufacturer. Calculating correct tyre pressure etc.
retiredChemist is offline   Reply With Quote
Old 12-05-2016, 05:09 PM   #13
Chassis: International S3800
digging up an old thread...
with me travelling between ohio and florida alot, now being winter I have to constantly adjust the tire pressures to make sure they are correct for the area im travelling...
do big riggers just set a pressure and forget or do they constantly adjust like im doing?
im adjusting at the beginning of the trip, the norning after my night stop.. (halfway).. and the norning after I arrive.. so the tires are always at their 'coldest' time.. of course that varies greatly with whether im in sunny 65 degree st pete(morning).. or in yucky 17 degree ohio(morning).. and then theres the daytime heating..
in ohio it may be 17 in the AM and only reach 25-30 in the daytime.. in florida it may go up to 85 and then the sun shining on the tires..
while I realize the tires are engineered to handle wide varieties of pressure.. i am working with 100 PSI here.. yes they are New tires..
nevertheless I dont want to end up cut in half...
so what shall i need to properly and safely inflate?
I read about "clip on air chucks.. " some with gauges.. but all have such short little hoses.. and people tell me stand off to the side when airing a tire.. never in front of or behind a sidewall.. well thats really tough with a little hose...
what do the truckers use? these guys dont seem to be getting injured by inflating tires and they must do it all the time... do they just stand in front of the tire and air-up anyway??
Love to hear form those who drive big rigs and / or busses for a living, esp across mulltiple climate zones..
Old 12-05-2016, 06:11 PM   #14
Engine: TE 444
Rated Cap: 12
Inflate tires cold to desired pressure, then ignore heat rise, the inflation max pressure on the tire is a cold pressure, so if you check later and you have 115 psi instead of 100 because you have been driving, you are fine. Most tire failures are due to being under inflated and getting hot because of it, or because of gross overloading of the vehicle, also most truck tires are rated 65 mph at max load and pressure, and if you are at max load, you want max pressure
Old 12-05-2016, 06:43 PM   #15
Chassis: IH
As a professional driver, 99% of us have a "set it and forget it" mindset. Inflate to proper pressure cold. Check when cold or when in doubt. Don't deflate when tires are warm - remember, they were designed to work this way. We don't adjust for winter/Florida temp differences. Basically, if it's showing 95+ PSI, we're good to go.
I drove for JB Hunt a few years ago and their company policy was "If it's showing 85 or less, we consider it flat", meaning it needed air pressure ... and as likely as not, needed to be checked to see why it was under 90.
Old 12-05-2016, 08:15 PM   #16
AlleyCat67's Avatar
Year: 2005
Engine: Detroit MBE906
That's how I was too.... set it, check it every day or so, adjust if needed, and roll.
If you have dual rears this might be something for you to look at as well... I have a pair of these that will be installed on my rears when I get them dug out of storage. Can tell at a glance if your pressure is too high or too low.
Another nice thing is if there is an inequality between the two tires it will transfer air between them to equalize it. But if one or the other blows it has a safety check inside it that will keep the pressure in the good tire so it doesn't go down.
I think they make these in 65, 90, 100, 110, 120 psi.
Old 12-05-2016, 08:16 PM   #17
good stuff... what about the proper procedure to inflate? did you guys just stand in front ofthe tire with an air chuck and gauge and go?
I know some will say use a bat.. I have not developed a keen sense with a bat... I set 1 steer at 100 and the other at 85 and batted away on both and couldnt tell the difference so I figured for now I'll use a gauge..
Old 12-05-2016, 08:34 PM   #18
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Use a pressure gauge, cold. A bat will only tell you that a tire is seriously low.
Old 12-05-2016, 08:42 PM   #19
Engine: TE 444
Rated Cap: 12
get one of these, threaded on the inside, weight of the air hose will keep it on the stem
Dual-Foot Lock-On Air Chuck | GEMPLER'S
I have one,just need to bring my big compressor to my current house
Old 12-05-2016, 09:44 PM   #20
I have a big compressor at the house but I'm also going to set up an air connect on the bus . I may locate it inside the battery box or tucked up under the hood. I'm usually checking the fluids when I'm checking tires so opening the hood is no big deal
