Old 07-28-2010, 11:15 AM   #1
Diesel Dan's Avatar
Engine: DT466/AT545
Fast drying but strong adhesive?
I'm wanting to use a sort of flexible 1/8" thick cork sheeting as a "headliner" on the ceiling of my bus:
http://www.corkstore.com/compass/servle ... nctionid=x
My biggest hesitation is the potential hassle of the installation process and fear that it may eventually start coming off. I'd like to use an adhesive that will allow me to just hold it for a minute or two and then it will be adhered. And of course the adhesive needs to permanently secure the cork to my painted metal ceiling.
Anyone have suggestions?
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 07-29-2010, 01:55 PM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: Fast drying but strong adhesive?
Originally Posted by Pied Typer
Contact cement? And the good news is that you'll probably get a nice buzz out of the deal too!
Use plenty of ventilation (don't just open a window, use fans!!!) Contains toluene... bad stuff that long term exposure causes nerve and brain damage. When you build laminate covered cabinets for a living, you are around the stuff alot. I often wonder if that is part of the cause of David's deafness.
http://en.wikipedia.org/wiki/Toluene
"Toluene should not be inhaled due to its health effects. Low to moderate levels can cause tiredness, confusion, weakness, drunken-type actions, memory loss, nausea, loss of appetite, and hearing and color vision loss. These symptoms usually disappear when exposure is stopped. Inhaling high levels of toluene in a short time may cause light-headedness, nausea, or sleepiness. It can also cause unconsciousness, and even death. Toluene may negatively affect kidney function."
Fulltime since 2006
Old 07-30-2010, 12:12 AM   #3
Hi, I had the same issue trying to hold up my foam insulation, I could not get the spray glue to act fast enough so I used the contact cement, it worked a lot quicker than the spray but with the cork being heavier I don't know. I also put plywood over the foam and screwed it down in several places, but I still have visions of the whole thing coming down on my head some night..... good luck, Leslie
Doodlebug is offline   Reply With Quote
To go really FAST frank-id Everything Else | General Skoolie Discussions 2 11-11-2012 01:23 AM
Adhesive Remover for left over glue under reflective stuff. 68camaro Conversion Tutorials and How-to's 7 04-14-2012 10:38 AM
replacing engine, cherry picker strong enough? adamanderr Conversion General Discussions 2 02-08-2010 10:01 AM
How fast is your bus esp uphill or into winds? nearhomeless Mechanical and Drivetrains 3 05-20-2009 10:03 AM
Must Sell Fast Please Help phillip266 Classifieds | Buy, Sell, Swap 0 04-04-2005 10:57 AM
