Old 09-01-2010, 01:32 PM   #11
Scratchy's Avatar
Engine: 5.9 Cummings
Re: Fastening plywood in a bus
LuLu,
I had a similiar experience with TEK screws when trying to fasten my plywood to the metal floor. The wings on the screws were causing the screws to strip out. At $8 bucks a box for the small screw count I was a little perturbed. I ended up grinding the wings off each of the screws, pre-drilled all of my holes and used them still to fasten down my plywood. Yes, it defeats the purpose of self tapping, but I will say they did hold tight very well.
Scratchy
Scratchy is offline   Reply With Quote
Old 09-02-2010, 03:53 PM   #12
Scratchy's Avatar
Its my understanding the whole premise of the 'wings' is to help bore through the wood and in theory break off when they actually hit metal. The screws I was using the wings didn't break off and continued through the metal. Thus when trying to actually tighten down the plywood to the metal floor the screw was stripping through.
Plywood floor sandik Conversion General Discussions 9 10-09-2013 11:31 AM
Replacing Rear Window with Plywood? lornaschinske Short-Bus Conversion Projects 7 08-04-2012 10:48 AM
Plywood that curls? Doodlebug Conversion General Discussions 7 02-06-2010 03:08 PM
OSB vs Plywood elkoskoolie Conversion General Discussions 9 07-19-2009 07:48 PM
Stained Plywood flooring? Highwayman Conversion General Discussions 3 11-18-2006 06:12 PM
