Old 08-04-2010, 06:04 PM   #1
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
Fastening plywood in a bus
Do the straight nails do ok for fastening finish plywood or does the bouncing and rattling around loosen them up too much.
tks for the replies
see my conversion at http://www.skoolie.net/gallery/v/Skoolies/Putters+Bus/
putterspitt is offline   Reply With Quote
Old 08-04-2010, 07:26 PM   #2
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Re: Fastening plywood in a bus
always use screws. nails will squeak and creek and work their way loose on ya.
Old 08-04-2010, 08:55 PM   #3
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
Sheet Metal Screws 1-2" based on how thick your plywood is. We used 2" with a 1/2" plywood, probably could've used 1.5" but I don't think HD had them.
Rutgers tailgating bus http://www.skoolie.net/forum/viewtopic.php?f=36&t=5545
RUskoolietailgater is offline   Reply With Quote
Old 08-04-2010, 09:38 PM   #4
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
thats what I used on the side walls, was going to try use something better looking
tks for the replies
Old 08-19-2010, 09:21 AM   #5
Scratchy's Avatar
Engine: 5.9 Cummings
Pura Vida,
I used 3/4 inch plywood and was glad I did. The 1/4 gives you a little more material to work with when your are fastening down other fixtures in your bus to the floor. Just my two cents worth.
Good luck.
Scratchy
Scratchy is offline   Reply With Quote
Old 08-21-2010, 09:21 PM   #6
Chassis: Farmall
Engine: DT-466
As far as sub-flooring goes, does anyone see any need for PT (pressure treated) plywood?
FLHRCI is offline   Reply With Quote
Old 08-21-2010, 09:25 PM   #7
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
pressure treated wood wil dry out and warp imo
Old 08-21-2010, 09:30 PM   #8
bus-bro's Avatar
Engine: 3208 na boat anchor
No, that stuff is poison. Keep it out of the living envelop. I've also heard the chemicals in some of the treatments react with steel, not for the better.
Old 08-30-2010, 11:22 PM   #9
RevBill's Avatar
Coachwork: - Still Shopping -
Chassis: - Going Medium/Large -
Engine: - DT466 Desired -
If moisture is a concern you can use a product like "DryPly" .. it's a tongue and groove sub-flooring designed for humid environments and occasional exposure to moisture .. it is not designed for prolonged or continuous use in "wet" environments (such as outdoors or for a deck) .. great for bathrooms, kitchens, and laundry rooms where you expect to get wet once in a while ..
.. it is also T&G, which makes for much stronger joints that won't "rack" or move horizontally when you step on them ..
.. it is available at most Home Improvement stores .. not much more expensive than regular T&G sub-flooring .. I would stay away from the OSB sub-flooring though, especially if moisture is a concern .. regular old T&G sub-flooring should hold up just fine, especially if you use a low-voc sealer ..
.. hope that helps ..
Chance favors the prepared mind. - L Pasteur
Luck is the residue of good planning. - B. Rickey
Travel is fatal to prejudice, bigotry, and narrow-mindedness ... - M. Twain
RevBill is offline   Reply With Quote
Old 08-31-2010, 07:07 PM   #10
RevBill's Avatar
Yeah Smitty .. it won't sheen water, it just resists deterioration from exposure to moisture .. won't help you at all with mildew/mold, or even pet odors for that matter ..
Plywood floor sandik Conversion General Discussions 9 10-09-2013 11:31 AM
Replacing Rear Window with Plywood? lornaschinske Short-Bus Conversion Projects 7 08-04-2012 10:48 AM
Plywood that curls? Doodlebug Conversion General Discussions 7 02-06-2010 03:08 PM
OSB vs Plywood elkoskoolie Conversion General Discussions 9 07-19-2009 07:48 PM
Stained Plywood flooring? Highwayman Conversion General Discussions 3 11-18-2006 06:12 PM
