Old 01-04-2008, 06:54 PM   #1
Chassis: Chevrolet
Engine: 8.2L Detroit Diesel
Rated Cap: 54
Faulty welds on Carpenter buses
I have an '88 Chevy Bus with a Carpenter body. Recently I learned about faulty welds on the roof structures of buses built in the Mitchell, Indiana plant from 1986-1995. This raises some concern to me, so I was wondering if anyone else with a Carpenter has heard about this issue. It seems like it might only cause problems in the event of a rollover, which hopefully will never happen to anyone. Ok thanks.
-Adam
arfisher83 is offline   Reply With Quote
Old 01-05-2008, 09:55 AM   #2
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
Re: Faulty welds on Carpenter buses
Hi Arfisher and welcome to the forum.
There has been numerous posts on faulty welds, on Carpenter buses. I think the first one was posted in 2005.
Here are some of the posts concerning the welds:
Carpenter Bodies http://www.skoolie.net/forum/viewtop...er+buses#p3370
Interior Panel Removal http://www.skoolie.net/forum/viewtop...er+buses#p3940
Brand new to skoolie's - inquiry http://www.skoolie.net/forum/viewtop...r+buses#p10662
1990 International-conventional 466/643 My new project! viewtopic.php?f=11&t=2382&p=17743&hilit=welds+carp enter+buses#p17743
CARPENTER SCHOOL BUS UPDATE:
Identifying the Potential For Cracked or Broken Welds http://www.schoolbusinfo.org/carpbusfinal.html
Hope this helps.
Robert
Roasting8 is offline   Reply With Quote
Old 01-05-2008, 10:46 AM   #3
Chassis: Chevrolet
Rated Cap: 54
Thanks for the info. I see it's a commonly-known problem. I'm no welder, so fixing the problem by myself, (if it needed to be done) is out of the question. Besides, I've already completed my insulation on the ceiling and put all my pine boards up, so I'm not going to remove all that now. Do you think that bad welds could cause problems with normal use - meaning occasional trips to the campgrounds? I'm also thinking about building a deck on the top once I've completed the interior. I want the deck to be about 8 feet long, so only about a third of the length of the bus. Would this be too much stress on the structure?
-Adam
Old 01-05-2008, 11:05 AM   #4
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
-Adam
Sorry Adam, but you're asking the wrong person. I remember seeing the posts throughout the years and thought I'd guide you to them.
In the last link, NTSB recommended for schools recommended for schools to take buses out of service, if they can. But, they also stated that if there was no other alternative, to keep the buses rolling. I suspect that most of the weld problems were an issue of safety, during roll overs, because the NTSB recommended that buses be used for low speed routes.
The only thing I can recommend is to inspect the welds before installing a deck. Maybe someone else that has a Carpenter bus can chime in.
Sorry, this is all I've sgot.
Robert
Old 01-05-2008, 11:32 AM   #5
lapeer20m's Avatar
i'd be willing to bet a carpenter with bad welds is still safer than most any motorhome.
Old 01-05-2008, 02:02 PM   #6
KC10Chief's Avatar
Rated Cap: 60
I have a 1993 Carpenter. When I bought my bus, it had a salvage title because of this problem. I am also an amateur welder and have yet to see ANY faulty welds on my bus. They played it safe and gave all the Carpenter's salvage titles. To get the salvage status removed, I had to show some sort of repair bill. It was a real PITA since my bus didn't need any repairs. I explained the situation and even showed them the bus, but they said it needed some sort of repair bill or a receipt for parts to fix it. Finally, I went to Home Depot, bought a roll of welding wire for $8 for my welder, and took the receipt to the tag agency and that worked! No more salvage status for my bus. But I've had all of the ceiling panels and side panels off in my bus. I didn't see one weld that I felt was faulty. I was looking too. So, I'm sure there were some buses with bad welds, but not all of them. I really wouldn't worry about it. There was an incident a few years ago where a Carpenter rolled over and the roof partially collapsed. I don't think anybody was seriously injured. But they found that the cause was faulty welds on the roof of that particular bus. I guess they found a couple more buses with bad welds and just condemned them all! The way I figure it, is that there was one lazy piece of crap welder at the Carpenter factory back in the day. He couldn't have welded every single Carpenter together out there.
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
https://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
Old 01-05-2008, 07:37 PM   #7
reprobate's Avatar
I second lapeer!
reprobate is offline   Reply With Quote
Old 01-05-2008, 07:55 PM   #8
Chassis: All American RE
Engine: Cummins 8.3
There is info about the problem in an article on this page:
http://www.schoolbusinfo.org/press.htm
It actually looks like something that should be fixed if found - the roof collapsed in the rollover shown in that article. It's still probably safer than a commercial RV, but it's pretty easy to fix I think...
dentarthurdent is offline   Reply With Quote
Old 01-05-2008, 08:42 PM   #9
Chassis: Chevrolet
Rated Cap: 54
Alright, thanks for the advice. I guess as long as I don't roll my bus over bad welds shouldn't be a concern.
Old 01-05-2008, 09:40 PM   #10
Elliot Naess's Avatar
Engine: 5,9 Cummins
The Carpenter in question.
There were no children on board at the time.
I have found one reference to the driver, which reports that the driver was injured but expected to recover. http://www.schoolbusfleet.com/forum/...ida,crash,roof
Old 01-06-2008, 12:44 AM   #11
KC10Chief's Avatar
Rated Cap: 60
I never actually saw any photos of the bus. That looks like one of the flat front Carpenters. Quite a bit different than my dog nose. But that roof is totally screwed. Even if you did have bad welds, it's an easy fix if you have an angle grinder and a wire feed welder. I really don't give it much thought on my Carpenter.
Matt
7.3L diesel w/AT545
Carpenter Roof Welds busdriver_phil Conversion General Discussions 8 02-13-2024 05:08 PM
Carpenter noises Zephod_beeblebrox2 Everything Else | General Skoolie Discussions 7 12-13-2014 01:28 PM
Faulty AT 545 Tranny Temp Sensor... HELP CVanDamme Everything Else | General Skoolie Discussions 6 09-21-2008 12:22 PM
Party Buses (In Buses In The News) lapeer20m Everything Else | General Skoolie Discussions 4 07-03-2008 02:43 PM
Buses buses, ya wanna know about buses ??? frank-id Everything Else | General Skoolie Discussions 0 10-19-2006 11:42 PM
