Old 01-16-2017, 12:36 AM   #1
sammy's Avatar
Coachwork: Gillig
Chassis: Phantom Schoolbus
Engine: Detroit Diesel 6v92TA
Feedback for post on Insulation
Hey everyone, would you be willing to give me your thoughts/feedback/corrections to my recent post on insulating your bus? My goal for it is to be a good resource that gives someone a general understanding of what to do, without going into exhaustive detail of every option. Let me know if there are more photos/explanations/diagrams that would be helpful.
I'm considering a paragraph about vapor barriers (basically, my take on it is that they don't really make sense for a bus, but I thought I should explain that) thoughts?
Thanks!
Insulation — Buslandia
Visit my Skoolie resource website - www.buslandia.net
sammy is offline   Reply With Quote
Old 01-16-2017, 06:57 AM   #2
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
great job Sammy. #1 with propane heat if you use a vented model you wont have a moister issue. and #2 in the insulation pic shows the wood furring strip against the metal rib, it should have a thermal break between the two. just my 2 cents.
my build pics
Old 01-16-2017, 07:14 AM   #3
Engine: Navistar 7.6L
What sort of thermal break on top of ribs?
DoubleO7 is offline   Reply With Quote
Old 01-16-2017, 09:42 AM   #4
sammy's Avatar
Coachwork: Gillig
Good point on the propane, I'll add that in. On point #2, isn't the furring strip itself a half-way decent thermal break? I mean it's wood, so not perfect by any means, but seems like it would be adequate.
Old 01-16-2017, 10:02 AM   #5
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Wood will transfer heat and cold. I just insulated , I have pics In my build album. Just another way of doing it. Its not perfect.
my build pics
Old 01-16-2017, 11:23 AM   #6
sammy's Avatar
Coachwork: Gillig
do you have a photo of what you used for a thermal break between the furring and the ribs? or can you just tell me what kind of material you'd recommend, and how you attached it.
Old 01-16-2017, 11:59 AM   #7
per dave's album link in his post, it appears he used 1/2" blue foam board as thermal break material.
Old 01-16-2017, 12:50 PM   #8
sammy's Avatar
Coachwork: Gillig
ah, missed that. Thanks!
Old 01-16-2017, 02:55 PM   #9
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
That was the first try but i ripped it all out. After i sprayed foamed even with the ribs i put 1/2 poly board up with a few screws here and there till i put the plywood strips up. I used self tappers to secure the strips to the ribs. I used a long piece of steel to shave of the excess foam using the ribs for a guide.
