Old 01-03-2011, 01:55 PM   #1
Seeria's Avatar
Fiberglass insulation rolls for flooring?
Is there any reason why fiberglass insulation rolls can't be used as flooring insulation? I noticed they're higher in R factor than insulation boards. I'm thinking of laying a barrier, laying a R13 or more rolls down with supports to hold flooring material and keep from smooshing the insulation.
Also noticed they're 3 1/2" or more thick. Would it ruin their R factor to compress them a bit? How much compression is too much?
Old 01-03-2011, 02:21 PM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: Fiberglass insulation rolls for flooring?
Don't compress more than 1/2 of their regular thickness (ie= 3" can be compressed down to 1.5" before you lose so much R value that you are wasting your time and money). Polyiso sheathing (foam board... NOT THAT STYRO FOAM BEAD CRAP) ) has a higher R-Value can hold up to getting wet without losing R Value and will not "shift" over time.
Fulltime since 2006
Old 01-04-2011, 06:30 AM   #3
Seeria's Avatar
Okay, you all win I'll stick to the boards *grumble grumble*
fiberglass or steel? wmkbailey Conversion General Discussions 15 09-28-2013 07:21 PM
Painting Fiberglass Bus Stuff Conversion General Discussions 7 10-05-2012 11:14 AM
Mahogany Rolls royce lornaschinske Everything Else | General Skoolie Discussions 3 03-09-2010 02:25 PM
Living as the bus rolls. SeanF Skoolie Conversion Projects 0 03-18-2009 12:32 PM
cheapest insulation and flooring skoolie_grease Conversion General Discussions 6 03-31-2005 02:45 PM
