Old 05-08-2010, 09:33 PM   #1
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Re: Filling in a hole in the floor
I would probably cut some sheet metal a little bigger than the hole and attach it from below with either short metal screws or rivets, with a little sealant to keep the moisture out. Then if you replace the plywood floor you just go over it, and if you choose to keep the plywood floor, cut some plywood circles and drop them in with some building adhesive or other sealant. OR...use the hole to plumb in your toilet or sink or shower.
Old 05-08-2010, 10:30 PM   #2
bus-bro's Avatar
Engine: 3208 na boat anchor
Fiberglass tape and epoxy resin works well for something like that.
Old 05-09-2010, 10:05 AM   #3
Year: 1978
Coachwork: thomas
Chassis: ford
Engine: 406 Ford
Rated Cap: 25
Originally Posted by Smitty
Doesn't look like holes for heater....or that they've been there for nearly 20 years.....lol, metal isn't even rusty.
Smitty
...or 2" thick! Sorry- couldn't resist.
bus-ted is offline   Reply With Quote
Why is there a hole in the bottom of our hot water tank? freakn Conversion General Discussions 6 09-08-2011 02:58 PM
Mysterious Floor Hole lornaschinske Conversion General Discussions 4 04-04-2011 02:01 PM
Has anyone Filled in a window hole on a Fiberglass Bus? Stuff Short-Bus Conversion Projects 1 05-26-2010 10:04 AM
Advice on body work / filling holes? nyrockingchairs Conversion General Discussions 6 10-12-2007 12:37 AM
Hole in Floor for Storage. Coma Conversion General Discussions 6 07-21-2006 10:20 AM
