Old 07-02-2017, 04:30 PM   #1
First Floor Plan - Help!
Howdy!
I'm in the earliest possible stage for planning my skoolie. Don't even have a bus yet. I'm in no hurry for this project and want to get it right the first time.
Below is my first floor plan. I'm hoping to get a Thomas or a Blue-Bird with the engine in the back. To show my "noobness" I forgot to compensate for the wheel wells. Working off the idea that the bus will be around 35' with a 7.5' interior. If those dimensions are in error, hey, school me
Trying to keep the living area as open as possible. The kitchen needs to be substantial because I love to cook. The rest is just utility.
Please, if you have any suggestions, I'll take 'em! I have no ego to bruise.
You can view a higher res photo if you have Google+
https://plus.google.com/+DaveHearn/posts/CRdsAKX1gLd
-Dave
(Diving right in)
davehearn is offline   Reply With Quote
Old 07-02-2017, 05:14 PM   #2
Evertiro's Avatar
I'm not much farther than you are (technically, I may be behind you... I haven't started working on a blueprint yet, though I have a TON of research done), but I believe the wet wall is usually on the drivers side.
Evertiro is offline   Reply With Quote
Old 07-02-2017, 05:33 PM   #3
Good point! Is this due to the position of grey/fresh tanks in the under carriage?
With the design I have going, I can flip the spare beds / bath and kitchen pretty easily.
Well, on paper anyway.
Old 07-02-2017, 06:13 PM   #4
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
My bus is 30' from the doghouse in the back to the line. You can build over the wheels; they don't take up much space.
Old 07-02-2017, 06:17 PM   #5
Reversed that wet wall and utilities
Also added real dimensions to the washer/dryer combo, fridge, and stove
David Hearn: Skoolie Floor Plan
Old 07-02-2017, 06:42 PM   #6
Thanks for the reply! 30 feet. I could divide that space between the living area and the kitchen.
Where can I see pictures of your rig?
Old 07-02-2017, 07:33 PM   #7
@CaptSquid - what do you mean by the "line"? Front of the bus or just behind the cockpit?
Thanks again!
Old 07-02-2017, 08:37 PM   #8
Evertiro's Avatar
I'm guessing that he means the literal line that usually divides the drivers area with the seating area in a bus.
Old 07-02-2017, 09:15 PM   #9
That's what I'm thinking too, Griff. The floor plan holds up in the short-term, the design is 34' and some change to the back of the cockpit.
All this is academic, though. No plan survives engagement with the enemy!
Old 07-04-2017, 06:43 PM   #10
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
I have a 36' er bus. 32' from the back of the cockpit to the rear window, but the engine housing takes a chunk out of the floor.
Sent from my SM-N900P using Tapatalk
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
