Old 08-06-2007, 10:34 PM   #11
Year: 1950
Coachwork: don't know
Chassis: cheverolet
Engine: to be determined
Rated Cap: 28
Re: flea bay tankless water heaters.
think its something I want to experiment with
delbertinie is offline   Reply With Quote
Old 08-06-2007, 11:37 PM   #12
the_experience03's Avatar
Well, it could be a supplement which would REALLY cut down on energy usage, but I'm fully convinced that during the summer months it would provide enough heat on its own. On a hot day your car can get to 150 degrees. I think that a device that is DESIGNED to get hot in the sun could hit 150 degrees easily as well. Now assuming you used proper materials with low thermal coefficients it could heat water from say 60 degrees in the tank to 100 degrees at the tap relatively easily. You're not going to get hot, steamy showers, but you aren't going to be checking around for appendages that seem to have shrunken up and disappeared afterwards either.
Again...it's all just theory. That's the beauty of this busing hobby. You are free to do whatever you want whenever you want and you usually have an interested crowd following along. Fail or succeed, atleast I can count on the skoolie crowd being accepting and understanding.
Old 08-08-2007, 10:26 PM   #13
Year: 1950
Chassis: cheverolet
Rated Cap: 28
the way to invent is to try, success comes from failure. GO for it
good luck
Old 08-08-2007, 11:15 PM   #14
Elliot Naess's Avatar
Engine: 5,9 Cummins
I have one of those 115 Volt shower head heaters here -- still in the box. I'll report back once I get it working.
Elliot
Old 08-10-2007, 09:15 PM   #15
Year: 1950
Chassis: cheverolet
Rated Cap: 28
cool I'll keep watching for your post
dale
Old 08-10-2007, 10:34 PM   #16
swinada's Avatar
why not mount one of those on the roof of your bus?
2 - 2'x20' pre-plumbed panels
Heats pools up to 24'
For pools 24' and over additional panels required
Increases your pool water temperature up to 10 degrees
Most efficient solar panel in the industry - producing over 80,000 BTUs a day
Compatible with your existing pool pump
10 year prorated warranty
Better than a gas heater - no gas line, no gas bills, no pollution
Made in the USA for quality you can count on
More Tubes per panel than other brands!
I'm sure they would provide you with plenty of warm water to take showers etc.
I was thinking if I could somehow mount this on the roof or have it stored in my storage boxes while driving and set it up when stationary. The water lines could be plumbed with quick connectors, only need a pump to get the water up and then its gravity fed.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
http://picasaweb.google.com/swinada/BusPictures http://www.swinada.com/bus.htm
http://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 08-10-2007, 10:43 PM   #17
Year: 1950
Chassis: cheverolet
Rated Cap: 28
with the water adding weight to the unit itself, how much weight would the roof need to carry
most importantly would it. am assuming that this is apretty big unit?
neat idea tell us more
dale
Old 08-10-2007, 10:45 PM   #18
Engine: 5,9 Cummins
Price?
I've been thinking just a bunch of ABS pipe on the roof.
Elliot
Old 08-10-2007, 11:08 PM   #19
swinada's Avatar
buy it now price on e-bay is $149, but there is many that are auctioned off and they go anywhere from $80 up or so.
One panel with water is around 45lbs. each kit includes 2 panels, could mount one on the left and one on the right. Defenetly not to heavy for a busroof.
SunGrabber
Above Ground Pool SOLAR HEAT EXCHANGER
DESCRIPTION: The Sungrabber™ Solar Collector is manufactured in Chico, California. The collector
is a specially developed, highly stabilized polyolefin and is of parallel, circular channel
design. It is unglazed, un-insulated, and designed for low temperature applications
such as swimming pool heating, heat pumps, aquiculture, and hydroponics.
DIMENSIONS:
ROOF MOUNTING SPACE: Width = [Number of panels X 27 in. (68.6 cm)] + 24 in. (61 cm)
Length = Panel length + 24 in. (61 cm)
RACK SPACE: Width = [Number of panels X 27 in. (68.6 cm)]+ 2 in. (5 cm)
Length = Panel length + 6 in. (15 cm)
WEIGHT: Without Water:
2 ft. X 20 ft. 12.3 lbs (5.6 kg) or 0.27 lbs/ft2 (1.3kg/m2)
With Water:
2 ft. X 20 ft. 43.4 lbs (19.7 kg) or 1.0 lbs/ft2 (5.0kg/m2)
TEMPERATURE: Normal operating temperature = 60oF to 90oF (16oC to 32oC)
Maximum continuous operating temperature = 212oF (100oC)
Maximum intermittent temperature (un-pressured) = 250oF (121oC)
Melt temperature = 338oF (170oC)
FLOW: Maximum recommended flow = 4 gpm per panel
Minimum recommended flow = 1 gpm per panel
Recommended flow = 3 gpm per panel
PRESSURE: NORMAL OPERATING MAXIMUM INTERMITTENT
PRESSURE PRESSURE
80oF (27oC) 0 to 30 psi 45 psi
(0 - 2.11 kg/cm2) (3.16 kg/cm2)
212oF (100oC) 0 to 5 psi 5 psi
(0 - 0.35 kg/cm2) (0.35 kg/cm2)
70oF (21oC) Measured burst pressure of panel body = Over 300 psi (21.1 kg/cm2)
TM
2ft x 20ft:
Effective Area
243.25 in (6.2 m) 39.0 ft2 (3.6 m2)
239.25 in (6.1 m)
23.5 in (0.60 m) 27 in (0.68 m)
PRESSURE DROP:
CHEMICAL RESISTANCE: Compatible with common collector fluids
CORROSION: Non-corrosive
FREEZING: The system should be drained before freezing conditions occur.
WEATHERABILITY: Weatherometer, accelerated outdoor exposure, and other extensive laboratory testing
demonstrates long-term weatherability of Sungrabber™ collectors (see warranty).
Additionally, Sungrabber's experience of 30+ years and over 1,000,000 collectors
installed confirms the proprietary stabilization and high mechanical strength.
ABSORPTIVITY: 0.96
EMISSIVITY: 0.90
All specifications and dimensions set forth above are as estimated by SunGrabber, but are not intended
to be precise and should not be relied upon as precise without independent verification. These estimated
specifications and dimensions are subject to change without notice. Nothing contained herein is intended
or should be construed to expand or extend SunGrabber 's warranty, or establish any express or implied
warranties of any nature, other than as contained in the Limited Ten Year Warranty Agreement.
(SunGrabber disclaims any other warranties and assumes no duty to provide notice if it becomes aware
of any deficiencies in these estimates.) The reader accepts full responsibility for any use or application of
these estimates and specifically understands and acknowledges the limited reliability of these estimates.
Additional test data available on request
P/N 07532B
09/06
link to pdf file http://www.sungrabber.net/SunGrabber...pec_07532B.pdf
http://www.sungrabber.net/SunGrabber_Pool_Heater.html
Old 08-10-2007, 11:15 PM   #20
Them thar skoolie roofs can hold some weight
RV On Demand Tankless Water Heater lornaschinske Conversion General Discussions 3 01-26-2011 08:47 AM
Tankless LP hot water heaters on the CHEAP! tfdfyrman Conversion General Discussions 3 07-03-2009 10:16 PM
Tankless Water Heater (link, under $200) fireman69 Conversion General Discussions 2 10-30-2008 11:54 PM
MAREY Tankless Water Heater Coma Conversion General Discussions 18 07-09-2008 08:18 PM
Tankless water heaters KC10Chief Conversion General Discussions 16 04-02-2008 11:48 AM
