Old 04-03-2012, 09:15 PM   #21
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Re: Floating floor squeaks?
Originally Posted by keith
...if some one said not to do it,than don't do it,,,end of discussion...
Don't complain about discussion topics.
There, I said not to do something....let's see what happens.
Old 04-03-2012, 09:41 PM   #22
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Here a good one to think about instead of squeaks floors and tire presser & bs ,,think about this ,,how to make your diesel run on multi fuels ,like motor oil or jet fuel,not bio diesel or veg oil.. . do.like the military trucks M35a. diesel not getting any cheaper nor veg oil.....so think about this,it would make a good discussion
keith is offline   Reply With Quote
Old 04-04-2012, 11:24 AM   #23
I think we need a discussion about how much vegtable oil we use on the floor to eliminate squeaks...
Old 04-04-2012, 11:50 AM   #24
...never use veggie oil...it will go bad and stink
.maybe a nice coat of KY
.plus you could slip and slide down the aisle
Old 04-04-2012, 02:22 PM   #25
lornaschinske's Avatar
Rated Cap: 89
PERVERT!
Fulltime since 2006
Old 04-04-2012, 05:09 PM   #26
TygerCub's Avatar
Engine: Detroit
I was thinking bacon grease. Talk about stinky!
One of the guys at work told me his grandfather used to pour bacon grease around the bottom of fence posts to keep them from rotting away from moisture. All I could think was how bad it must have smelled and how many bugs it attracted.
Old 04-25-2012, 04:00 AM   #27
dip drill bits in bacon grease before you chuck them up in the drill press.. also works when needing lube for your lathe tool.
Old 04-25-2012, 05:29 AM   #28
TygerCub's Avatar
Engine: Detroit
Then you get to work with the scent of cooking bacon! Mmmmmm!
I finally decided to glue the foam to the floor, then glue the wood to the foam. Before I add the final flooring surface, I'll add 1 to 3 screws around the edge of each sheet of plywood (depending on size). That will help maintain the distance from the wall.
Unfortunately, until I can get help with the generator out of the bus, I'm at a standstill with the flooring. So I've moved on to plumbing and building the framework for the walls.
Old 05-17-2012, 02:55 PM   #29
mayordejorno probably loves bacon,
almost there with the floor butcher_boy Conversion General Discussions 2 06-07-2011 12:33 PM
Securing things to a floating floor opus Conversion General Discussions 3 09-21-2010 10:32 PM
My floor thoughts opus Conversion General Discussions 4 07-24-2010 09:32 AM
Floor: Floating or not? John Conversion General Discussions 2 08-06-2008 06:51 AM
3/4 ply vs 3/4 osb for floor busone Skoolie Conversion Projects 6 10-09-2005 09:07 PM
