07-27-2017, 03:32 PM
Coachwork: Carpenter (Cavalier)
Chassis: International Harvester
Engine: DTA360
Rated Cap: 63
Floor adhesive removal
After I pulled the rubber floor up I would like to prep for painting but I need to remove the remaining glue. Any advice. I have tried scraping and it comes of but takes forever. I used an angle grinder with different discs too; the wire brush almost take it all off but I can still see an impression of where it was, the flap disc and scotch brute both work great but they also remove the galvanization.
So I guess the real question is, would rolling rustoleum oil based primer/paint onto bare steel get a better adhesion or would I get a better adhesion of rustoleum by leaving the galvanized steel intact?
I think I want the galv to keep its sacrificial properties, but if the paint won't stick as good maybe I should just rely more on the rustoleum to protect from rust.
07-27-2017, 03:35 PM
Grab a gallon of Ospho. Great for galvanized floors with or without rust. To paint galvanized steel you need to etch it first, so the oshpo takes care of that.
07-27-2017, 03:44 PM
what are you going to cover the floor with? I have both left the rubber on the floor before carpeting, and removed also in a flx bus.. works either way
07-27-2017, 03:45 PM
Engine: DTA360
Rated Cap: 63
The Glue.
Flap disc/Scotch Brite
Wire wheel.
07-27-2017, 03:46 PM
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I covered mine with carpeting and linoleum. No probs.
07-27-2017, 03:49 PM
Engine: DTA360
Rated Cap: 63
So are you suggesting it is better to leave the galvanized coating on and just remove the glue residue from the surface?
07-27-2017, 03:53 PM
Engine: DTA360
Rated Cap: 63
I was planning OSPHO, rustoleum primer, seal all holes, rustoleum paint, 2" pink foam board (floating), 5/8" plywood, then eventually some finished flooring (tile bathroom and wood stove area, and bamboo or hardwood or maybe vinyl the rest)
07-27-2017, 05:27 PM
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Sounds good to me. Don't get hung-up on perfection.
Get 'er done.
07-27-2017, 06:14 PM
yeah. Then ospho it.
Sounds solid to me.
07-27-2017, 06:35 PM
Engine: DTA360
Rated Cap: 63
Get 'er done.
Im going for it.
07-29-2017, 11:59 PM
Engine: 3208 na boat anchor
I used 1" pink board and 3/4" tongue and groove plywood for the floor. Standard building supply stuff, and I can still stand up straight.
07-30-2017, 12:32 AM
Engine: DTA360
Rated Cap: 63
Standing up won't be a problem since my room is now 8 ft. But I will use tounge and groove if I can find it. Maybe even 2" pink board.
