06-19-2017, 05:12 PM
Coachwork: Thomas EF
Floor Hatch
06-19-2017, 08:42 PM
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
That's really clean. Looks nice.
06-19-2017, 08:49 PM
That is a very nice job. Everybody is going to think you've got a safe in your floor.
When I saw this thread I thought it was going to be about a floor hatch that you could use to drop down under the bus, like an escape hatch. I'm not sure what occasion would make it necessary to exit the bus that way, but hey.
Robin
Nobody's Business
06-19-2017, 09:43 PM
Can never have too many escape hatches haha
06-19-2017, 10:50 PM
Year: 90
Chassis: international
If this hatch is where people walk someone is going to get tripped up and hurt. You should not have any raised surfaces in walking areas.
06-19-2017, 10:56 PM
It will be under the bed.
06-20-2017, 02:09 AM
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126
... yet you still made it nice and purdy. That's how I know you love your bus. Good job.
06-20-2017, 11:21 AM
Exactly!!! Thank you Marceps.
06-20-2017, 12:09 PM
I'm only in like with my bus. This one isn't pretty.
Robin
Nobody's Business
06-20-2017, 02:34 PM
James Bond bus.
Damn near dead center for the fuel tank. That was my thought. I'm going to trip over that sucker before I remember it's there.
Really? Lucky. Mine is up front and will be the center of the "living room".
06-20-2017, 02:38 PM
That is quite unfortunate. Ours is perfectly centered in the back 1/3 of the bus but the bed will cover the left side of the hatch and part of our water tank will probably sit on it. It will still be a pain to get to if needed but emptying a water tank and moving storage items won't be as bad as cutting the hole when/if needed.
06-20-2017, 02:52 PM
Front third on mine.
Hey wait a minute, my bus is an RE. Why the hell is the fuel tank there??? There is literally nothing behind it (by +90 something inches) and nothing in front of it (30 something inches). The filler neck has plenty of room to move forward before the door would be in the way. And of course there is nothing in the way out back except the diff pumpkin and wheel wells.
Shorter fuel lines to the engine is a good thing. Longer wires to the dash are a lesser evil than longer fuel lines. I already block all the pumps getting fuel. Hmm, I might need to look at moving the tank sooner than later. It's only a 60 gallon tank so I kinda want to replace it with a 100 gallon anyway. Or add a second and plumb them together.
06-20-2017, 02:53 PM
We have a FE and the tank is in the rear. It's also a flat nose. Maybe it's for safety.
06-20-2017, 03:00 PM
Also a flat nose; 40'. Can't put it all the way in the back where the bed would be since it's a RE; the engine, tranny, and driveshaft are in the way. In front of the rear wheels would still leave it in a living space but would be bathroom. I could move it closer to the front wheel well. But if I I'm doing is hiding the filler neck, I can do that most anywhere with cabinets. Don't think I want it forward of the front axle even if it would fit (not sure it would).
Guess I need to borrow Millicent's tape measure and get to work!!
06-20-2017, 03:01 PM
Sounds like too much work haha.
06-20-2017, 03:04 PM
If I could hide the center hatch no. And if I upgrade the tank capacity maybe not. For just the filler neck, most definitely.
