Old 01-20-2018, 04:19 PM   #1
Traveling
Floor Insulation
I can do 2" of insulation on the floor cause I'm only 5.9. Does it matter if the rigid foam is under a plywood subfloor, or on top of it? what is our goal, to keep heat and cold from coming up through the floor or escaping down through the floor. I know I want at least 1/2" of rigid under my floor to house the PEX hydronic system. Would 1" rigid with 1/2" plywood and then another 1" rigid be a good solution? That way I'm only going through 1" of foam to secure any cabinetry.
Old 01-20-2018, 05:22 PM   #2
Thomas1985's Avatar
Chassis: GMC G3500 Vandura
Engine: V-8 5.7L Gas
You could also consider using metal instead of wood and have room for more insulation instead. Also, it will never rot.
Thomas1985 is offline   Reply With Quote
Old 01-20-2018, 06:10 PM   #3
Traveling
Metal for what?
Old 01-20-2018, 06:57 PM   #4
Robin97396's Avatar
Like a nice brass floor to go with your hydronic heating system?
Robin
Nobody's Business
