Old 05-27-2018, 04:34 PM   #1
Coachwork: BlueBird / Microbird
Chassis: Chevy 3500
Engine: Chevy Vortec 6.0 gas
Rated Cap: 30
Floor insulation
Ready to lay flooring insulation.
I’ve been told—given the very very good condition of the metal sheeting—that I don’t ‘need’ to paint it first. But it’s a shortie and we’re only talking ~15 feet, so I want to paint it. Rustoleum, yes?
Now, the rigid insulation: should it be polyiso R-max or the pink / blue stuff (xps?).
Please give your reasoning; I’ve read so many conflicting “use THIS” responses.
Also (if it matters) I am NOT framing the floor, though I will sheet over the foam with plywood.
Thanks!
Whywalk is offline   Reply With Quote
Old 05-27-2018, 04:49 PM   #2
No matter the condition, painting the floor is preventive maintenance, Rustoleum is what a lot use. IMHO, I doubt you would see much performance difference between the foam boards.
o1marc is online now   Reply With Quote
Old 05-27-2018, 04:58 PM   #3
Chassis: Chevy 3500
Rated Cap: 30
Yes, I thought preventative was a swell idea.
Thanks for taking time to respond.
Old 05-27-2018, 06:06 PM   #4
Chassis: Chevy 3500
Rated Cap: 30
Old 05-27-2018, 06:17 PM   #5
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
The difference in polyiso and xps from what I've been reading, is only in cold so if you plan on staying out of harsh cold you shouldn't see a difference
Whatthefak is offline   Reply With Quote
Old 05-27-2018, 06:27 PM   #6
Chassis: Chevy 3500
Rated Cap: 30
I’d like to be prepared for any situation 👍
I think I’ll go with the XP’s on the floor.
If I’ve researched enough, am I correct that I won’t need a vapor barrier underneath either the foam or plywood?
Old 05-27-2018, 06:53 PM   #7
And just how significant is that difference?
Old 05-27-2018, 07:19 PM   #8
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
From what I've read it's not huge, the bigger difference is in the foaming gas from brand to brand and how fast they off gas and lose R value
Old 05-27-2018, 09:16 PM   #9
joeblack5's Avatar
Year: 98
There is a no doubt biased article from owens corning. Search polyiso versus xps.
Xps absorbs more water if exposed and at 15f the r value drops from 5 to 2 . . so for the floor I would stay away from xps.
Later j
Old 05-27-2018, 10:20 PM   #10
Whatthefak's Avatar
Chassis: Thomas
Engine: 5.9
Later j
I've read alot on it from different sources. The gist of what I got is there are people in the industry pushing for better real life measure of R value because of the life span of foaming gases, some have larger molecules and permiate the foam cell wall more slowly and the gases have better insulation property than air.
By the numbers alone xps looks better and does perform better in heat, but the cheaper pink board seems to be longer lived and performs the same in heat and cold, but at a slightly lower R rating
I'm not an expert, that's just what I got from researching because I live in Wisconsin and don't want to be cold.
