Old 10-07-2017, 01:13 PM   #1
Floor prep
Getting ready to begin framing and putting in a floor. There's a rubber aisle and lots of screws in the floor that are pretty full of dirt and gross as well as metal trim. What are yalls thoughts on leaving or removing these?
Was thinking about just leaving them and putting a floor over them because they seem inconsequential and taking them out would just mean more holes to fill in. Current plan is to just scrub the floor really well and lay 2x4s across for ribs, insulate and put a floor on top of that.
McPuccio is offline   Reply With Quote
Old 10-07-2017, 01:35 PM   #2
Coachwork: New Flyer
Chassis: D45HF "Viking"
Rated Cap: 51,600
I think the "old-timers" on the board will tell you that pulling up the rubber mat is wise. It allows you to see and take care of any rust on the metal decking before the floor rusts out and you find yourself sleeping on the ground....
I'm going to do that to my coach bus. The rust on the frame of my bus gives me dread about how much moisture has gotten to the floor....
MarkyDee is offline   Reply With Quote
Old 10-07-2017, 04:36 PM   #3
BowserJournal's Avatar
Chassis: Ford B600
Rated Cap: 20 person
We removed everything to the bare metal. That way we can treat the surface rust and build up from there.
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
BowserJournal is offline   Reply With Quote
Old 10-07-2017, 04:40 PM   #4
Anything worth doin, is worth doin RIGHT!
Old 10-07-2017, 04:55 PM   #5
Chassis: Saf-T-Liner MVP ER
... and keep the photographs, because "doing it right" adds thousands (or at least will make it much easier to sell) if you ever want to sell it.
I've seen quite a few attractive conversions that I would walk away from, because they didn't insulate the floor, or the ceiling. The problem is that to put that right means the bus has to be gutted ... again.
Steve Bracken
Build Thread
