Old 07-13-2012, 08:42 PM   #1
Chassis: P40 Mini Bird
Engine: 5.7L Chevy
Rated Cap: 13
Flooring & Sub Flooring Question
After reading numerous threads, I was wondering why everyone installs fir strips under wood flooring (laminate flooring or the like). I understand if it's for insulating purposes or if it provides a space for insulation, but can't I simply lay the laminate flooring over the top of the existing fireproofing coating that exists on top of the plywood & metal floorpan? This is in a 1997 Mini Bird P-Chassis bus that I'm converting to a tailgating machine. Thanks in advance for any help!
Devil Bird- Skoolie Short Bus Tailgater Conversion In Progress- Started 7-12-12
QUIKSVT is offline   Reply With Quote
Old 07-14-2012, 09:11 AM   #2
Re: Flooring & Sub Flooring Question
if you have a plywood floor, in my estimation, you can.. my last bus had a plywood floor, and i did just that.
its best to use the underlay first, though
in my current bus, i just removed all the metal center strips, reglued the rubber center strip upside down and added pergo flooring directly on top of that with glue... its been that way a year, and it works fine. no movement, just stays put.. but, i plan on never going to a cold climate, being only between oregon and alabama, so am not worried about insualting the floor..
did double insualte the sides and the roof, though, for the heat.. even with the main entrance door open, it is still pretty cool when the temp gets over 80 outside...
Flooring Tiger Bus Short-Bus Conversion Projects 37 02-15-2016 10:49 AM
FNG question on flooring. Scooter141 Conversion General Discussions 9 06-26-2013 05:05 PM
flooring. butcher_boy Conversion General Discussions 5 05-10-2010 07:13 PM
flooring joshritchie Conversion General Discussions 6 03-12-2009 10:50 AM
Flooring phillbus914 Conversion General Discussions 2 05-26-2008 09:11 AM
