Old 10-08-2009, 07:40 PM   #1
Diesel Dan's Avatar
Engine: DT466/AT545
Flooring Options
I'm starting a new thread so as to not hijack the floor insulation thread...
I'm about to start a skoolie project, and flooring will one of the first issues I have to tackle. What recommendations do people have about flooring?
These are my (ranked) priorities:
1. Maximum headroom is essential
2. There needs to be some sort of thermal/sound barrier under the flooring.
3. It needs to be affordable
4. I prefer hard flooring rather than carpet
Also, I will not have much open floor space in my design. I could conceivably use different flooring under beds, bathroom, kitched cabinets, etc. as opposed to what is in the open space. So far though, I'm thinking my best option may be linoleum over plywood. But that just doesn't sound very inspiring.
Thanks!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 10-08-2009, 09:26 PM   #2
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Flooring Options
Originally Posted by Smitty
Polystyrene or R-max in 3/4" + 3/4" plywood for the entire bus shouldn't run you much more than a $200-225 (ish) to do the entire floor (25-30')
Smitty
The current flooring is 3/4" plywood + 1/4" black rubber. With this combo the headroom is 6'5". I cannot have any less headroom than that. So I am restricted to 1" of flooring material total.
Gallery:
Conversion Thread:
Old 10-09-2009, 09:34 AM   #3
Diesel Dan's Avatar
Engine: DT466/AT545
So in terms of plywood, am I right in assuming that anything less than 3/4" is probably not good? If I went with 1/2" ridgid insulation and 1/2" plywood, would the floor flex too much? Or have other problems?
Gallery:
Conversion Thread:
Old 10-14-2009, 10:41 PM   #4
Diesel Dan's Avatar
Engine: DT466/AT545
Thanks for the advice Smitty. I will have a better sense of the actual headroom when I pick up the bus this weekend. The seller says current headroom is 6'5". I am 6'4". So every fraction of an inch is critical here. I may have to settle for just 3/4" plywood and Linoleum. The whole reason for getting a Thomas hightop is so I will not be stooping. So that is really my first priority.
Gallery:
Conversion Thread:
Old 10-15-2009, 12:24 AM   #5
Diesel Dan's Avatar
Engine: DT466/AT545
Keep this in mind....how much time will you actually be standing in your bus? I had to think seriously before taking the can-opener to mine, and I came close to deciding against it, now I'm glad I didn't. The deciding factors for me were that I'll be living in my bus, and I already have spinal problems. I also love to cook, and to eat, so I will spend a fair amount of time at the stove.
Like you, I have spinal problems and like to cook and eat. That is the exact reason I want the headroom. I don't really know yet how much time will be spent standing in the bus, but having my back act up in the middle of a vacation because I'm stooping/slouching around in the bus would really suck.
I'll definitely bring a camera and try my best to document my project as it progresses.
Gallery:
Conversion Thread:
Old 10-16-2009, 03:28 PM   #6
Diesel Dan's Avatar
Engine: DT466/AT545
Moderator: is there a way to just combine these three threads into one?
Gallery:
Conversion Thread:
Flooring & Sub Flooring Question QUIKSVT Conversion General Discussions 1 07-14-2012 10:11 AM
These are my options opus Everything Else | General Skoolie Discussions 7 07-04-2010 07:33 PM
How do I tell what options a bus has? zamfir Everything Else | General Skoolie Discussions 2 06-08-2009 09:33 AM
What Are My Options? retrogeek42 Conversion General Discussions 2 09-27-2008 09:22 AM
More options busone Conversion General Discussions 0 01-25-2005 08:56 PM
