Old 01-01-2016, 07:44 PM   #1
2kool4skool's Avatar
Foam food for thought
Spray Foam Insulation: Hidden Dangers & Health Risks spark Lawsuits
And the other side:
http://www.advancedinsulationla.com/...-benefits.html
http://sprayfoam.com/spray-foam-educ...wners-guide/25
Don, Mary and Spooky the cat.
Old 01-01-2016, 08:27 PM   #2
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Wow, that's a bummer.
I'm hungry!
You Gotta Let Me Fly
Old 01-01-2016, 10:00 PM   #3
I've seen similar stuff about the foam before.
Old 01-01-2016, 10:47 PM   #4
charles_m's Avatar
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
A lot of the negatives are from bad installation and improper curing time before occupancy. I'm still sold on it
www.bustoshow.org
Blog: www.lookatthatbus.com
Instragram: @lookatthatbus
Old 01-01-2016, 11:48 PM   #5
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
I've had between 4-6 inches of foam in my house for the last 8 years supposedly giving me r51. We have never had problems with it.
When it was installed we were living in the house, however a portion that was somewhat sealed off. We have only had problems where traditional fiberglass and plastic were used. Actually the worst problems are where we transitioned from foam to fiberglass.
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
Hank's P-O-S is offline   Reply With Quote
Old 01-02-2016, 12:16 AM   #6
I'm only slightly concerned.
Old 01-02-2016, 01:07 PM   #7
Moderator
crazycal's Avatar
Stupid is as stupid does. Who would stay in the house at the foam is being applied? Are the installers wearing masks? I think one of the complaints about Great Stuff spray foam. It doesn't cure fully.
I'm hungry!
Old 01-05-2016, 09:51 PM   #8
ii_amnt's Avatar
Isn't polyurethane foam outdated? As in, not even available for use in homes anymore because everyone knows it's bad stuff?
-Travis
1991 International. DT360. Spicer 5-speed manual transmission. Work in progress; spray foam, wood stove, etc...
ii_amnt is offline   Reply With Quote
Old 01-05-2016, 10:35 PM   #9
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Figured this might be reverent.
The canadian spray foam tech specs.
Technical Documents | CUFCA
Old 01-06-2016, 03:24 PM   #10
ii_amnt's Avatar
I am no expert on this stuff, but here is some brief things I found on a quick google search.
https://en.wikipedia.org/wiki/Insula...ation_material)
Here are the one's wiki lists, and are likely most common (in order of descending R value)
Polyisocyanurate spray foam
"...relatively strong molecular structure, because of the combination of strong chemical bonds, the ring structure of isocyanurate and high cross link density, each contributing to the greater stiffness than found in comparable polyurethanes. The greater bond strength also means these are more difficult to break, and as a result a PIR foam is chemically and thermally more stable: breakdown of isocyanurate bonds is reported to start above 200°C, compared with urethane at 100 to 110°C."
So, perhaps a bit better than straight polyurethane...
Closed-cell polyurethane spray foam
Phenolic spray foam
Seems this one is faily unstable, it will shrinks and can deteriorates in moisture or sunlight
Icynene spray from allinoneinsulation.com
"Icynene (LD-C-50™)1 is a low-density, open-cell, water blown, polyurethane foam insulation that is made from petroleum-based plastics. Icynene LD-C-50 is a two-part, spray-applied product consisting of polymeric isocyanate (Component-A Base Seal®) and a proprietary resin (Component-B, LD-C-50 Resin or Gold Seal®)2."
Open-cell polyurethane spray foam
-Travis
Old 01-06-2016, 06:01 PM   #11
Coachwork: Collins
Chassis: Ford E350
Engine: 7.3L diesel
Rated Cap: 18
Well, one is a law office's "fear, uncertainty, and death" message about foam, and the other is industry saying, "No worries!"
They both have at their core the desire to make money off you.
Puggy is offline   Reply With Quote
