Go Back   School Bus Conversion Resources > Bus Conversions > Conversion General Discussions
Click Here to Login
Old 08-25-2017, 11:26 AM   #1
RC000E's Avatar
Coachwork: Ford
Chassis: E450 #Vanlife
Engine: 7.3 Powerstroke
Rated Cap: 25
For those will tile bathrooms/backsplashes...do they hold up to road vibration?
We are debating wall finishes and I am wondering if tile is holding up to the vibration and harshness over time. Worst thing would be to start having cracks and fractures 1yr in.
Any word?
RC000E is offline   Reply With Quote
Old 08-25-2017, 12:29 PM   #2
I put floor tile in my last bus with good result. It was a bit different though. It was an Eagle 10 not a skoolie. Similar concerns though, flex & vibration.
I put down two layers of 3/4 exterior plywood glued and screwed. Then a layer of 1/2 cement board glued and screwed. The RedGuard and finally the tile.
It was HEAVY.
I ran over 200k miles on all sorts of roads and did manage to crack one tile. It was one that I notched about 80% of its depth to accommodate a doorway.
I really liked it but the weight may be a bit much for some skoolies.
I think a properly applied tile backsplash is entirely doable though.
Old 08-25-2017, 01:48 PM   #3
T-Bolt's Avatar
Engine: DT530
You will have the most problem with the grout cracking. Use a polymer based grout that is intended for use with luxury vinyl tile (LVT). I have used it on lots of projects with a zero failure rate.
Sent from my SAMSUNG-SM-G930A using Tapatalk
https://eternitybus.com
T-Bolt is offline   Reply With Quote
Old 08-25-2017, 04:09 PM   #4
I have seen this in manufactured homes. They used standard grout and it cracked and came out in chunks. The ground it all out and re grouted with the flexible stuff.
In mine the regular grout held up fine but I went to great lengths to stiffen the sub floor.
Old 08-25-2017, 04:15 PM   #5
Smaller tile and two-part epoxy grout will provide the best results. But only if the surface is extremely rigid and somewhat isolated from body flex. Even then there can be issues. Me...I'd avoid tile.
Old 08-29-2017, 05:48 PM   #6
I don't have any experience with it, but what about peel and stick tiles?
squeak is offline   Reply With Quote
Old 08-29-2017, 06:33 PM   #7
T-Bolt's Avatar
Engine: DT530
These are 12 inch by 24 inch luxury vinyl tiles with polymer grout. I installed these in my foyer just this past week. Have installed them in several other homes and they hold up really well too floors that Flex.
Old 08-29-2017, 07:18 PM   #8
Good call. Vinyl will take the abuse and flexing, ceramic will usually crack.
