Old 02-28-2019, 09:53 PM   #1
? for you experienced RVers!
Which side is most practical to hookup for water?
jee.string is offline   Reply With Quote
Old 02-28-2019, 10:24 PM   #2
RV parks are set up to service water, electric and sewer on the driver side.
Old 02-28-2019, 10:55 PM   #3
good to know!
Old 03-01-2019, 12:04 AM   #4
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Yes, usually all three are close to each other towards the end of the space so inlets and drains are ideal far to the aft on drivers side.
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 03-01-2019, 07:06 AM   #5
Johnny Mullet's Avatar
Engine: T444E 7.3L
I had to research this before setting up my interior of my bus. Driver's side hookups at every RV park I stayed at.
Old 03-01-2019, 10:03 AM   #6
Chassis: Navistar
Rated Cap: 30
Does anyone regret going passenger side or further towards the front driver for any of their utilities? Our exhaust unfortunately blocks undercarriage storage in the traditional hook up spot. We will have our potable gravity feed and shore water intakes in that general area, grea water under the bus opposite, then electric in the middle of driver side. We will not have a black tank, so my only concern is having to dump gray across the chassis. FYI we don't plan on visiting a lot of RV parks, but are keeping state & national parks in mind.
BusNameTBD is offline   Reply With Quote
Old 03-01-2019, 10:16 AM   #7
We put our gray tank on the passenger side. We haven't done a great deal of emptying it, but the couple times we did it wasn't a problem at all. Just had to make sure we pulled up close enough to the dump station so the hose reached. I bought a hose extension just in case I run short sometime. As far as flow restrictions or something like that....no problems at all.
Old 03-01-2019, 05:05 PM   #8
Mine has a space in the left rear that is about 2' x 8' and has the last section of exhaust pipe mounted in the middle totally wasting that space. If you cut 6-8" from the first bend in the exhaust and then again about 20" or so from the other bend . Take the bent section you cut off, rotate it 180 and attach it back. This deleted the 8" of 4" exhaust pipe from that space and routes the exhaust out the side behind the rear wheel. Frees up that corner space for a storage bin or propane tank.
Old 03-02-2019, 10:29 AM   #9
Chassis: Navistar
Rated Cap: 30
Thanks Drew. I'll check into that hose extension. Seems like a good thing to have stuffed in the back of a bay in case the need ever arises.
Very much appreciate the detailed instructions o1marc! This seems like an easy enough solution to free up that space.
Old 03-11-2019, 09:42 AM   #10
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
I just recently changed my exhaust set up. It originally exited the rear and after the rear end was in the passenger side taking up all that precious underbelly space.
The plan was to exit behind the rear tire. Well, after inspecting the exhaust,I had holes in it between the front and rear tires. So I removed it up to the holes. Cut out good sections of the pipe to reuse and cut out two of the 45 angles of pipes from where it went over the rear end.
4" exhaust band clamps to attach the picture together. Some 4" pipe hangers to hold them in place. Now it exits in front of the rear passenger tires. Put a nice black exhaust tip on it as well.IMG_20190311_093449_RAW.jpeg old exhaust location IMG_20190311_093408_RAW.jpeg new exhaust exit IMG_20190311_093414_RAW.jpeg band clamped and hangers. Paint Ted flat black with high temp paint
Nick
Old 03-11-2019, 12:01 PM   #11
I also brought the exhaust out in front of the rear pasenger tire. If I had it to do again I'd have sent the exhaust out the drivers side--away from the picnic table location and out from under the awning.
Old 03-11-2019, 01:01 PM   #12
I just did the same last week. Cut the 8' end pipe off and then a cut between the 2 45s and a 4 band clamp and it runs out about 1.5' behind the rear wheel. Freed up the only place for the 48" propane tank. I powder coated the tip in Silver Vein.
Old 03-11-2019, 01:47 PM   #13
Ninjakitty's Avatar
Running out the driver's side was my original plan. I didn't have any flex exhaust to go over the driveshaft though.
Great location for exterior outlets on yours.
Nick
Old 03-11-2019, 01:50 PM   #14
If you ran it out behind the rear wheel the driveshaft doesn't come into play. I like the idea though and will look and see if I can utilize the 6' section I cut off and do it all with existing parts. I'm thinking under bay storage may be in the way.
Old 03-11-2019, 01:52 PM   #15
Ninjakitty's Avatar
If you ran it out behind the rear wheel the driveshaft doesn't come into play. I like the idea though and will look and see if I can utilize the 6' section I cut off and do it all with existing parts. I'm thinking underway storage may be in the way.
I agree, but I couldn't get the angle correct because of the storage box and then I found the holes in the middle section of pipe. As it is, I deleted about 12' of exhaust, maybe more and went from 5 turns I. The exhaust to two 45 angles.
Also, my mini split compressor is in the way to run it out the driver's side behind the tires
Nick
Old 03-11-2019, 04:53 PM   #16
I checked and there is just enough room to do it. Room just behind the mudflap.
Old 03-11-2019, 06:23 PM   #17
Ninjakitty's Avatar
Nice. I feel it was worth it to get rid of the extra turns and open up the space.
Nick
Old 03-11-2019, 06:30 PM   #18
I think on mine I might only need to cut one pipe, turn it around and it should be right where I need it. When the ground dries I'll climb under and check it out. Any negative reason to not have the exhaust on the drivers side? Normally I would not be concerned, but you all have made me picture times I would be "picnicing" next to the bus and need to have it run for a reason, out the other side would definitely be a benefit.
Old 03-11-2019, 06:32 PM   #19
Ninjakitty's Avatar
I found that since I mostly drive in the right lane, the exhaust isn't smoking out the cars next to me.
The driver's side is probably preferable for the camping reasons you mentioned. I did passenger for the ease of it.
Nick
Old 03-11-2019, 07:27 PM   #20
I did mine driver side ahead of the rear wheel so when I use that side view mirror I can see the state of the smoke happening during a cold start and while driving. Early detection for my mind of how the engine is performing at any time either cruising or pulling hard on grades.
I like to see anything but white smoke.
Agree picnic side could be a problem at times but hardly ever picnic with engine running. However, loading from the passenger side door may attract some fumes I'd rather not breathe when I'm idling.
My 2 cents,
