Old 04-03-2019, 01:56 PM   #21
yeah its too bad they didnt put the turbos on DT's at the back.. being on the side makes them tough in a flat nose bus to get at
Old 04-03-2019, 01:58 PM   #22
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
It's that tube that goes into the top of it. Im thinking it's oil lubed and cooled?
Dead pirate is offline   Reply With Quote
Old 04-03-2019, 02:04 PM   #23
yeah! thats exactly the case. turbo's flow a lot of oil.. that bearing gets hot at 25000 RPM.. on my DT 360 there is a little gasket under that flange and 2 bolts to hold it on.
the return line off the bottom is low pressure but can still leak.. not as common as the high pressure line leaking though.
Old 04-03-2019, 02:10 PM   #24
Coachwork: myself
Chassis: amtran
Yup. That's it. I should have changed that seal. It came with the rebuild gasket set. Kicking myself for that simpler mistake
Old 04-03-2019, 03:48 PM   #25
I can't agree. It seems they could not have out it in a more convenient place to work on it.Or are they elsewhere on a 360?
Old 04-03-2019, 03:51 PM   #26
Coachwork: myself
Chassis: amtran
I have an RE and it's tucked. I wish it was that easy on mine. I have the dt466e
Old 04-03-2019, 04:53 PM   #27
Coachwork: myself
Chassis: amtran
Hey Christopher, what's the idle oil pressure? It isles at 35 or a little more. Reved It hits 50
Old 04-03-2019, 04:57 PM   #28
thats normal.. the book says anything 10 and above at full-temperature idle Is OK.. and 35+ at rated RPM (2300) is acceptable..
my DT360 idles at 25 or so in Hot weather and runs up to 50 at speed
Old 04-03-2019, 04:57 PM   #29
Coachwork: myself
Chassis: amtran
Sweet, before it idled at 45. Thanks again.
Old 04-03-2019, 05:16 PM   #30
idled at 45 full operating oil temp?? ie after driving on the highway?
either that thing had some thick oil in it or crazy tight bearings
Old 04-03-2019, 05:24 PM   #31
Coachwork: myself
Chassis: amtran
Yes. That's what it idled at. It was thick, but not that thick.
Old 04-03-2019, 05:25 PM   #32
Coachwork: myself
Chassis: amtran
I'm thinking bearings. They were all worn.
Old 04-05-2019, 08:04 PM   #33
Coachwork: myself
Chassis: amtran
Im stuck out on the road. The tranny is acting up. Can you help me? I can tell you what the display is doing. You can call me?
