Old 09-17-2006, 08:23 PM   #1
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Freshwater/Greywater/Propane/Electricity usage
Some figures based on our first 48 days of bus-living:
-70 gallons of freshwater lasts 8-9 days
-60 gallon greywater needs emptying every 7 days
-20 lb of propane lasts about 45 days (standard 20" gas range and on-demand water heater)
-We use 60 amp-hours/day, or 720 watt-hours (I work from home, and am on a desktop PC and satellite internet 8AM-5PM, 5 days a week.)
Just an FYI. This is for 2 adults and 1 cat.
Post your numbers if you want, fellow fulltimers. Help the newbies, wannabes and lurkers.
Sean
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 09-17-2006, 09:32 PM   #2
GoneCamping's Avatar
I don't have my numbers down like yours. I have a water electric site and for $3 the campground comes around with the honey wagon and takes care of my sewer for me!
As such, I've got 30 gal gray and 30 gal black tanks. I never fill the black tank, and use facilities showers so I can get by for a week and half on the gray tank (but I have it emptied every Saturday)... Propane...that's the big unknown, I've got a pair of 20# tanks, and usually can get at least 2 months out of each one if I only use it to heat water. Now keep in mind I run the water heater for about 10-15 mins per day, then I turn it off (DSI controlled). I do most of my cooking on a gas grill outside that utilizes a seperate propane tank.
Winter heating I use one or two electric space heaters, I set them on 600W setting (usually only use one unless it gets down into the teens). I have only a 30amp system, but two heaters at 600W uses less power than one of them at 1500W... both can run and still have lighting, the TV, and my laptop/WiFi...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Solar vs. Grid usage inkblots84 Conversion General Discussions 0 02-24-2013 04:31 AM
Best type of bus for highway usage... Flannel Conversion General Discussions 3 05-27-2011 08:26 PM
Solar power and usage drchefscott Skoolie Conversion Projects 7 02-07-2009 07:22 AM
GONE: 68-gallon freshwater tank SeanF Classifieds | Buy, Sell, Swap 4 07-31-2008 04:16 PM
