Old 08-14-2015, 01:18 PM   #1
cullengw's Avatar
Coachwork: Navistar
Engine: Allison
Rated Cap: 60
Question Front Step Ideas
Hi all,
I am trying to decide what to do in the driver/front step area flooring wise. Can I see some pictures of your guys' setups at the moment. Currently mine is just the original floor. MY best bet is to run laminate but i am wary to do so since that will be a very high traffic area
Pics would be great! Advice is Welcome! Movie critics are the Devil!
Thanks you!
cullengw is offline   Reply With Quote
Old 08-14-2015, 01:33 PM   #2
USMCRockinRV's Avatar
Chassis: Safe-T Liner MVP
Engine: 12V Cummins
Rated Cap: 75
Front Step Ideas
I used woven bambooClick image for larger version
Extremely durable and water resistant
Thomas
Safety Liner MVP
USMCRockinRV is offline   Reply With Quote
Old 08-14-2015, 01:58 PM   #3
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
I used poly-vinyl rubber flooring that has a diamond tread pattern. Water PROOF and slip resistant. HD sells it on line. Sorry I don't have pics.
Old 08-14-2015, 02:56 PM   #4
Coachwork: Thomas International
Engine: T444E V8 7.3L
Originally Posted by USMCRockinRV View Post
I used woven bambooAttachment 8250
That's nice. Is the rest of the bus flooring the same?
enoved is offline   Reply With Quote
Old 08-14-2015, 04:06 PM   #5
Engine: 12V Cummins
Rated Cap: 75
Yes it's all Bamboo front to back
Thomas
Safety Liner MVP
Old 08-14-2015, 04:32 PM   #6
Engine: 190hp 5.9 Cummins
Laminate is made from glued together press wood and should not be installed in a bus.
Vinyl plank looks just like laminate, but contains no wood to swell, buckle and rot.
Cost is around the same per square foot.
Old 08-14-2015, 06:15 PM   #7
Engine: 12V Cummins
Rated Cap: 75
I used the Vinyl Laminate on the face of my steps. I didn't want to loose any depth to my steps. It's held up very well. I believe I used "walnut"...
Thomas
Safety Liner MVP
driver, floor, laminate, steps
