Old 04-16-2009, 12:56 PM   #1
newbusser's Avatar
Year: 90
Coachwork: blue bird
Engine: Navistar Straight 6 Turbo
Fuel guage not working right
Can anyone tell me how to test a fuel sending unit?
I pulled them out and one looks new and other is very old. when they were in, neither was working right, or at least the gauge wasn't reading correctly. I drained both tanks, and when I selected the drivers side tank it said it was empty, select passenger side it says it's full. I then put ten gallons in each side and tried again....no change. Any suggestions?
“Twenty years from now you will be more disappointed by the
things that you didn't do than by the ones you did do. So throw off
the bowlines. Sail away from the safe harbor. Catch the trade winds
in your sails. Explore. Dream. Discover." Mark Twain
newbusser is offline   Reply With Quote
Old 04-16-2009, 03:15 PM   #2
Re: Fuel guage not working right
remove the guages, are the floats empty or full of fuel? if they float hook them up to a ohm meter and slowly move the float assembly thru the range, they should read close to each other in the empty and full positions, if they both test good, adjust the length of the float arms so that the float swings from the bottom of the tank to the top of the tank.
Old 04-16-2009, 03:44 PM   #3
Coachwork: 2003 Thomas E-350 shorty
Chassis: E350
Engine: 7.3 Powerstroke
Rated Cap: 24
And make sure that there are no baffles or other obstructions restricting their movement, both now and when (if) you put them back in.
If it isn't grown, it has to be mined
elkoskoolie is offline   Reply With Quote
Old 04-16-2009, 08:27 PM   #4
the_experience03's Avatar
Disconnect the wiring from the sender. The gauge should read either full or empty. Then ground the connector with a jumper wire. The gauge should move to the opposite end of the spectrum. If it doesn't you have wiring or gauge issues, not sender issues.
Old 04-16-2009, 09:52 PM   #5
also chech the tank switch it should measure no resistance, just continuity from guage terminal to one sener terminal or the other.
Old 04-17-2009, 12:41 AM   #6
newbusser's Avatar
Year: 90
checked each sending unit on bench.( your suggestion was great Vanguy, I just didn't see it till I had them out
One showed change in ohmmeter, other didn't so I took them both to the truck parts house and ordered another one just like the one that works. They were two totally different styles, now will be the same. I am going to clean the connecting wires completely before I install them and see what happens.
Old 04-18-2009, 09:35 PM   #7
lapeer20m's Avatar
and make sure the resistance of the sending units is matched to the guage.
Old 04-18-2009, 09:42 PM   #8
newbusser's Avatar
Year: 90
Still fighting it. I am leaning toward bad grounds, but now when I put new sending unit in, both tanks read full, I put switch to center spot and guage says empty. Am going to clean all connections and try some of the troubleshooting techs tomorrow when I have my son available to tell me what the gauge is doing.
Also, I know the tanks are not full because I ran it dry...... there are a number of four letter words I want to use, but decorum forbids it. Got it running again, but took most of the day.
Old 04-19-2009, 10:55 AM   #9
lapeer20m's Avatar
you might want to try getting a new guage if the grounds check out. A sending unit and a guage usually come as a matched set. a guage is designed for a certain amount of resistance, and the sending unit is also designed to provide the proper amount of resistance for that particular guage. Having a guage that does not match a sending unit would make things not work properly.
Gas and temp guage malfunction saljal Mechanical and Drivetrains 3 11-20-2013 09:33 AM
When not working on the Skoolie... browncrown Everything Else | General Skoolie Discussions 4 01-21-2013 07:06 PM
STILL working on my bus! KC10Chief Conversion General Discussions 1 08-23-2008 12:46 AM
Sheet metal guage for windows Billsman Conversion General Discussions 12 05-13-2008 04:39 PM
Propane Tank Sending Unit / Fuel Guage Workings Gyva Alternative Fuels | Electric, Propane, Wood & Biofuels 3 02-28-2007 10:06 PM
