Old 10-15-2009, 07:29 PM   #1
Joseph Cabot's Avatar
Coachwork: Ward
Engine: International DTA-360
Send a message via MSN to Joseph Cabot
Fuel tank capacity
Does anyone have an idea of fuel tank capacity on a full size bus? I am going to get a bottle of winter diesel fuel conditioner and I would like to fill the tank up. There is currently a little over 3/4 tank, so I hope that it doesn't take too much $$.
Bus Photos | My Blog
Joseph Cabot is offline   Reply With Quote
Old 10-15-2009, 08:44 PM   #2
GoneCamping's Avatar
Re: Fuel tank capacity
I'm sure there are various sizes for various buses... My Thomas has a 95 gallon tank...
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 10-15-2009, 09:25 PM   #3
My 1990 International is 60 gallons.
Abbott is offline   Reply With Quote
Old 10-16-2009, 07:47 AM   #4
Coachwork: Ward
I hope mine is 60 gallons. Even at that size it will still cost around $35-$40 to fill up the rest of the way. I am going to drive the bus Monday for the first time after buying it in June. I will go to the station a couple miles away and blow the cobs out.
Old 10-23-2009, 12:51 PM   #5
Coachwork: Ward
I put $20 in the other day. It didn't fill it up from 3/4 tank, so I will try again in a week or so. Diesel is $2.75/gal here.
Old 10-24-2009, 03:15 AM   #6
the_experience03's Avatar
I don't think you're going to find a tank smaller than 60 gallons. Most of the newer buses are larger to give them more range. My 60 gallon tank will only hold 30 or so. There must be a trap door baffle or something hung up in it. I just haven't gotten around to investigating further because honestly...after 200-some miles I'm ready to take a stretch break anyway.
Old 12-14-2009, 12:36 PM   #7
Coachwork: Ward
Finally filled my tank all the way this morning. I put in $20 twice an $18.00 today, so it took about 21 gallons total from 3/4 tank. I have only started the bus once a week and let it run for 5 minutes or so. I drove it to the gas station 3 times. So I think it must be around a 75 gallon tank.
Installing a different tank mount and/or fuel tank jazty Conversion General Discussions 16 09-15-2014 05:42 PM
Tank capacity? porkchopsandwiches Plumbing, Water and Waste 3 12-12-2013 04:17 PM
got scangauge \ need fuel tank capacity gbstewart Conversion General Discussions 5 04-24-2012 08:06 AM
Holding tank capacity BUSBOZO Conversion General Discussions 8 05-13-2010 10:01 PM
wvo fuel tank on my bus mike Veggie Oil | WVO | Biodiesel | SVO 1 01-06-2009 11:16 PM
