Old 03-29-2018, 07:10 PM   #1
Mgulley82's Avatar
Chassis: 40' Saf-T-Liner MVP ER
Engine: CAT 3126 7.2L
Gas tank access panel
Do most people cover over the gas tank access cover in the center of The floor?
It looks like you lose access to the fuel level sending unit, suction, return, fill and vent lines?
This is a 04 Thomas with FE 3126 CAT
Mgulley82 is offline   Reply With Quote
Old 03-29-2018, 07:25 PM   #2
Engine: MBE 904
yeah don't do that unless you're willing to drop the tank if you ever need to gain access to it. Luckily where mine is, is where we put the couch so it worked out. It's not the end of the world though. It would only take about 15 minutes to drop the tank with the right tools.
Gatorbait is offline   Reply With Quote
Old 03-29-2018, 07:27 PM   #3
Pygmy Yeti's Avatar
Year: '91
Engine: 7.3
Rated Cap: 71
I'm green to all of this but I've seen most people keep some sort of access to it. Usually a simple cut out that blends in with the finished floor. I know that if I cover mine up, the unit will need work within a week. Keep an access door and I'll never need to use it. Just how life works. I'm sure more experienced folk have some good ideas.
Pygmy Yeti is offline   Reply With Quote
Old 03-29-2018, 08:54 PM   #4
Mgulley82's Avatar
But what’s under it?
Just the fuel sensing unit?
Old 03-29-2018, 10:24 PM   #5
Jdawgsfanasty's Avatar
Here's my 2bits...if the manufacturer put it there then I'd leave operational...maybe hide it under a cabinet...but blending a accessible panel shouldn't be to difficult...
Jdawgsfanasty is offline   Reply With Quote
Old 03-29-2018, 11:43 PM   #6
Year: 90
Chassis: international
This is not a 15 minute job. When you count the safety cage, frame brackets and hard to get at fittings this is a 2 hour job minimum. And messy. It took me 2.5 hours to do an r/r on mine once. Keep the access panel . On one bus I was able to drop just one side, climb up between the floor and tank to change the sending unit. Looked like I had been crawling around inside an engine. Nasty
Old 03-30-2018, 03:55 PM   #7
I will third that emotion. Keep access.
