Old 09-26-2005, 09:05 AM   #1
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
Gas Tank Size?
I have decided to switch the bus over to run on gasoline. A fairly simple thing. I need to find a suitable fuel tank. To those of you with buses that run on gas, what size is your tank? Where is it located?
To everyone: Any sugestions? I am thinking of behind the rear differential between the frame would be a safe place for it. Although when my 250 litre propane tank was factory installed they placed it where I am guesing the gas tank would have gone because of a gas flip cover behind the stair well.
I am hoping to find somthing suitable in a junk yard. Could I use a tank that held diesel? I have seen a few around. They look nice and big.
Thanks. Looking forward to some advice. -Richard
Old 09-26-2005, 09:30 AM   #2
Steve's Avatar
The tanks on gas buses are usually either 30 or 60 gallons. I have a 30 gallon and I would suggest you get the 60. I am thinking of buying a second 30 and connecting them in series.
I don't think it will be hard for you to find either size from a gas bus in a junkyard, they are everywhere. (also on newer buses they have a big pipe to protect the tank in a side collision, if you mounted your between the frame rails you wouldn't need to worry about that.)
Old 09-26-2005, 02:16 PM   #3
We have a 1966 Chevy with a Wayne body and the tank is TINY! I'd estimate it at about 25 gallons, although I've never run it out to know for sure. All I know is that it reads empty at around 15 gallons used.
I'd be interested in running a bigger tank, if it could be done inexpensively.
66 Chevy Skoolie
Used for Tailgating to Kansas State University football games!
The seats are out (except for two facing each other) and replaced with matching couches.
7000 watt generator powering 2 6500 btu A/C's
Rebuilt 350 puts the power down.
66ChevyTailgater is offline   Reply With Quote
Old 09-26-2005, 08:52 PM   #4
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
First thing I'd do is make sure your guage, sending unit & their interfaces are working properly.
One of the first things I do with ANY vehicle I buy (including my bus) is to get a couple of jerry cans full of gas, fill up the gas tank, write down the starting milage, and run the tank dry so I KNOW where empty is, and roughly how many miles I can go until I will run out. I usually mix highway & city miles to try to get a more realistic idea.
Once I have determined how many miles I can go on one tank, and average how many miles per gallon the vehicle gets, I can drive without fear of running out by allowing myself a 50 mile buffer, i.e. if I get 300 miles per tank, I start looking for gas as I near 250 miles travelled.
Hope this helps, although I'm sure some one in this forum probably knows what size tank was installed when your bus went down the assembly line.
Griff is offline   Reply With Quote
Old 09-27-2005, 11:23 AM   #5
lapeer20m's Avatar
Most older buses i've seen have the fuel tank mounted just behind the stairs on the passenger side.
the brand new buses that have been driving around my county have the fuel tanks mounted behind the rear axle between the frame rails.
It seems that either location is a fine place to mount a tank.
Both buses i've owned have been diesel, one had a 50 gallon tank, and the new bus has a 60 gallon tank.
Old 09-27-2005, 06:35 PM   #6
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
That's where mine is. It is 20 years old, and it also has the huge "grunch" bar surrounding the tank.
Hey, that's where I put my propane tank mount! I'm not crazy after all!
I hope one day in the not to distant future to convert to dual fuel like you did. I'm going to try to mount a couple of 50 or 60 gallon tanks somewhere under the bus when I do, so I will have some real legs.
Old 09-29-2005, 12:50 PM   #7
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
re: Diesel fuel tank
So, I came across a free diesel fuel tank today. Looks as though it came off a large truck. I figure at least 50 gallons. It's aprox 6' long. I am wondering if it would be possible to use it as a tank for regular fuel. It would fit between the frame behind the rear axle (since my monsterous propane tank is behind the stairs) and it's free. Or, I'll use it as a grey water tank. Do you think this would work? I would attach an exterior fuel pump I guess. Where would I find the wires to attach fuel gauge?
-Richard
Installing a different tank mount and/or fuel tank jazty Conversion General Discussions 16 09-15-2014 05:42 PM
gas tank to Black tank? turf Conversion General Discussions 19 07-28-2013 07:15 PM
What is my gas tank size? kirkndopp Conversion General Discussions 1 12-24-2009 03:48 PM
Fresh, grey, and black water tank size. what do you have? Jerry Campbell Plumbing, Water and Waste 3 10-31-2008 09:56 AM
black/grey tank size/dimensions instal? beekay Plumbing, Water and Waste 0 10-13-2006 08:57 PM
