View Poll Results: What brand of generator have/would you purchase for your RV/bus conversion (cost included)
Honda 11 47.83%
Guardian series (Quietpact, Primepact) 1 4.35%
ONAN 6 26.09%
Other (please specify) 5 21.74%
Voters: 23. You may not vote on this poll
Old 05-18-2006, 06:05 PM   #11
I'll sit down and do this calculation, for sure. Some of this will be easier, I guess, once i have some of these appliances. As of now, it's all so hypothetical since I have none of them. The kicker is that my mother has MS and really has to be cool. So we're planning for her to man the wagon and watch in the cool while we're frying in the stands. You "Yankees" have it easy! Kidding--I know cold's your problem.
brentag is offline   Reply With Quote
Old 05-18-2006, 09:48 PM   #12
the_experience03's Avatar
When your temperature varies 150 degrees between January and July, come and talk to me
Record cold set a few years back here: -63* F
Record high set a few years back here: 121* F
Being the land of 10,000 lakes means we have *some* humidity too
Old 05-18-2006, 10:52 PM   #13
Wow. Point made.
Old 05-20-2006, 08:50 PM   #14
I believe the "D-name" A/C is Duotherm.
Here are some prices from work on gennies.
$180 (on sale) no name 800 cont/2000 watt
$550 Coleman 6250
$990 EU2000
$550 2500 watt Honda Harmony
I can get other prices if you want comparison.
Old 05-20-2006, 09:38 PM   #15
Did I mention my 10%+ discount?
Old 06-08-2006, 12:56 AM   #16
KC10Chief's Avatar
Rated Cap: 60
I have two of the Honda EU2000i generators for my travel trailer. I boondock everywhere I go. I never go to state parks or anywhere I can plug in. The Honda's were expensive, but worth it in my opinion. I bought them from http://www.mayberrys.com They are in New JErsey. Each generator was $879. No shipping charges and no taxes unless you live in Jersey I guess. I live in Oklahoma City and the cheapest I found them here was $1,100. I bought a parallel kit off of E-bay for $85. When they are both running, I have 4000W. That is more than enough to run everything in the trailer. A/C, microwave, TV and lights. They are extremely quiet as well. In the trailer, I can't hear them at all. Outside, it's very comfortable with them around. Normal conversation is no problem even with both of them running at full capacity. If you don't need the A/C, you can run just one of them and use half the gas. They are both extremely fuel efficent. The generators have 1 gallon tanks in them. I made external tanks for each generator out of 5 gallon gas cans and some stuff I bought at the hardware store. At the dirtbike races I go to, I get there Friday afternoon, start the generators, fire up the A/C, hook up the external tanks and let them run the whole weekend. I don't have to refill anything or even touch them once. By the time I shut them down on Sunday evening over 50 hours later, each generator has gone through about 4 gallons of gas. You don't get 4000W of power and have anything more efficent than that. When people walk up they have to get within a few feet of the generators to see if they are actually running. These things are great. They would be awesome for a skoolie or somebody who boondocks all the time like I do. They are also very easy to transport. Each generator is under 50 pounds. I can carry both of mine at the same time. Hondas rule.
Matt
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
http://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
Old 06-08-2006, 05:21 AM   #17
lapeer20m's Avatar
Originally Posted by KC10Chief
Hondas rule.
Matt
Couldn't have said it better myself!
Old 06-08-2006, 12:31 PM   #18
KC10Chief's Avatar
Rated Cap: 60
Oh yeah, Honda makes a 3000W quiet generator too, but it's almost $1,800!!! That's more than two Honda EU2000i's. With the EU2000's, you can just run them in parallel and have 4000W. If you don't need that much power, say in the winter, you can run just one of them. Also, the EU3000 is 150 pounds!!! Have fun getting that up in your bus. The EU2000's are about 48 pounds each. I don't know why anybody would buy Honda's 3000W generator and not two EU2000i's. Matt
Matt
7.3L diesel w/AT545
Old 06-08-2006, 01:54 PM   #19
lapeer20m's Avatar
there are 2 reasons:
The most obvious reason is that the EU3000 does 220 volts. You only get 110 volts with the pair of eu2000's
I'll try to make the 2nd reason about as clear as mud.....To get the EU2000's to work in paralell, they have to run in wide open throttle mode if i'm not mistaken making them consume much more fuel than if they are running in "eco-throttle" mode. @ 700 watts, the 3000 would consume about 1 gallon in 5.88 hours and the pair of 2000's would consume 1 gallon in about 2 hours. However, as you can see if you compare all the numbers, @ the rated paralell load of 3,200 watts the pair of smaller geni's consume the same amount of fuel that the eu3000 does @ it's rated load of 2,800 watts.
With eco-throttle on, the eu2000 geni runs aout 15 hours on a gallon (1.1 to be exact) of fuel @ 1/4 load. With eco-throtle off, the geni runs about 4 hours @ it's rated load (1,600 watts). A pair of them would obviously consume twice as much fuel as a single geni.
1/4 load is ~400 watts for the eu2000....
1/4 load is ~700 watts for the eu3000 (2800 watts rated)
eu3000 rated for 5.88 hours per gallon @ 1/4 load
or 2.11 hours per galon @ rated load (2800 watts)
the eu2000 will run a single geni 15 hours per gallon @ 1/4 load
or 4 hours per gallon @ rated load
or 2 Hours per gallon in paralell @ 3200 watts.
The 3000 watt geni is much quieter at quarter load than the pair of 2000's running full throttle, even though at full throttle the geni's are still very quiet. Noise, weight, and the need for 220 volts are the 3 biggest issues to deal with when deciding between the 2 geni's. Fuel consumption is not much of a consideration, unless you plan to run a single eu2000 in eco throttle mode.
For most of us, a single eu2000 is plenty, unless you have a big air conditioning unit. My eu2000 only gets excited when i run some high current draw device like the toaster, the electric griddle, or the coffe maker. Most of the time it just hums away near idle consuming it's gallon of fuel every 15 hours.
Old 06-08-2006, 02:20 PM   #20
KC10Chief's Avatar
Rated Cap: 60
Aah, I see. I run my EU2000's in parallel all the time. Using the Eco-throttle is no problem. You don't have to run them full blast the entire time. I have a 13,500 BTU A/C and just one of the EU2000's will run it, but it runs full throttle powering the A/C. If I have the eco throttle on with just one gen, and the A/C kicks on, it will usually overload the gen and it will kick offline. The A/C uses quite a bit of power to get going. I've read about installing a soft start switch, but it sounds like more of a hassle than it's worth. With both gens running and my A/C set at 73, I go through about 8 gallons of 91 octane in about 50 hours. Either way, they are great generators. Totally hassle free. They start on the first pull every time and run all weekend and I don't touch them thanks to the external tank!
On a side note, I've been reading your posts about your jacuzzi bus and the veggie oil conversion. I was going to convert my F250 over to veggie oil, but I'm going to sell it instead so I can get a bus and convert it. I may be hitting you up for advice soon. I also read the thread where you were stuck on the beach! That's a wild story. How's the tow bill working out for you? Matt
Matt
7.3L diesel w/AT545
Anyone need a generator? opus Electrical, Charging and Solar 9 04-10-2012 09:54 AM
Generator Nicholas5225 Conversion Tutorials and How-to's 3 06-09-2011 11:52 AM
generator pete36330 Classifieds | Buy, Sell, Swap 1 11-15-2009 11:33 PM
Where do i put a generator? Joe Monstermaker Conversion Tutorials and How-to's 1 02-16-2009 12:01 PM
AC/Htr and generator lseagro1 Conversion General Discussions 2 10-08-2004 04:30 PM
