Old 04-26-2018, 07:28 AM   #31
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
My champion 3100 W inverter generator that I have installed in a tray under the skirt is not bad. I havenít done anything additional to quiet it down, but when the bus engine is running, it is a rear engine configuration, I cannot hear the generator at all no matter how hard I try.
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 04-26-2018, 07:29 AM   #32
Chassis: Thomas
Engine: CAT 3126
This is how I have mine mounted, it is roughly midway between the axles on the drivers side.
My Build Thread:
Old 04-26-2018, 08:59 AM   #33
Brewerbob's Avatar
Originally Posted by david.dgeorge07 View Post
Attachment 21238
I have a gas 5500W already. I would prefer to have a diesel but since the other is free maybe I should just stick with it and install a fuel tank.
