Old 04-30-2008, 05:25 PM   #1
dancarrigan's Avatar
Ghost In The Brake Light Machine
The other night someone chased me down as I was walking my dog and said my brake lights were on.
I went back and sure enough, it was true. however, on the light diagram over the dash that indicates when and which lights are on, all was normal, i.e. no lights on. The bus was turned off and no key was in the ignition. I pumped the brake but the lights stayed on.
I was only able to get them to extinguish by turning the idiot switch that disconnects the battery but they turnd back on when I switched it back later, to see... I had an idea to start the engine and then the problem was solved. the lights went out.
Anyone have this kind of problem before?
Very mysterious....
djc
dancarrigan is offline   Reply With Quote
Old 04-30-2008, 06:28 PM   #2
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Re: Ghost In The Brake Light Machine
check for a brake light switch at the brake pedal when you push the pedal it opens the switch and allows the lights to come on if the pedal does not go up far enough the lights will stay on i hope thats it timbuk
Old 05-01-2008, 02:48 PM   #3
I'll check it out and thanks !
djc
brake light switch please help littleangel47 Mechanical and Drivetrains 3 08-07-2019 11:24 PM
brake light switch please help littleangel47 Mechanical and Drivetrains 5 03-19-2012 01:19 PM
Brake Pressure light.. colliervilledave Conversion General Discussions 6 07-23-2008 10:12 PM
brake light ? KaptnKAOS Conversion General Discussions 2 05-13-2007 07:40 PM
I'm having a brake light problem... DGC3 Everything Else | General Skoolie Discussions 3 04-18-2007 07:37 AM
