Old 09-07-2017, 11:26 AM   #1
Glue removal from the floor
Hello folks. I got the seats out and the rubber floor cover up, but there is a gummy glue residue on some parts of the floor. The floor is plywood, still in very good condition. I've seen some solutions for getting glue off a metal floor, but cant seem to find any easy way for wood. Wire brushes? Chemicals? Metal scraper? Help!
Hookhands is offline   Reply With Quote
Old 09-07-2017, 12:56 PM   #2
T-Bolt's Avatar
Engine: DT530
My plywood was in great shape as well but I cut out a small spot to check the steel below. Around the wheel wells it was rusted completely through. I ended up removing all the plywood and I'm glad that I did.
Sent from my SAMSUNG-SM-G930A using Tapatalk
https://eternitybus.com
T-Bolt is offline   Reply With Quote
Old 09-07-2017, 08:20 PM   #3
Skipoffools's Avatar
Coachwork: Carpenter (Cavalier)
Chassis: International Harvester
Engine: DTA360
Rated Cap: 63
I had success with citrus degreaser. Its biodegradable and smells like oranges. It's usually in the cleaning department at most hardware stores, about $10 a gallon. It took me a gallon it says you can dilute but I used it uncut. Sprayed it on with a hand sprayer, then after letting it sit (but not evaporate) I wire brushed with an angle grinder and washed it out with a garden hose. Worked great.
Skipoffools is offline   Reply With Quote
Old 09-07-2017, 08:36 PM   #4
BowserJournal's Avatar
Chassis: Ford B600
Rated Cap: 20 person
We removed the plywood as well. Our plywood smelled like diesel fuel. The previous owner I guess had spilled some. Plus the wood hid some rust holes so I am glad I did.
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
BowserJournal is offline   Reply With Quote
Old 09-07-2017, 10:54 PM   #5
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
I used Easy Release 1 Gal. Adhesive Remover by Henry at big box store.
Worked pretty good, have to follow directions.
Old 09-08-2017, 08:24 AM   #6
tobeamiss's Avatar
That plywood is very deceiving. Guaranteed you'll find rust under there. Besides you take away headroom if you're going to insulate over the plywood. I think if you go down to bare metal, you'll be happy you did. The plywood isn't that hard to remove once to get a system of using a 48" crow bar and 4 lb hammer. Mine came up pretty easy that way and I found rust in places I really didn't think there would be any where the wood looked good.
oh yes she did!
https://www.skoolie.net/forums/f11/to...-it-16557.html
Old 09-08-2017, 08:26 AM   #7
tobeamiss's Avatar
Attachment 15743
I wonder how well this would have worked on the adhesive left behind from the reflective strips on the exterior?
oh yes she did!
Old 09-12-2017, 08:24 AM   #8
We decided to take up the plywood, but now I have a couple other questions. We weren't planning on installing insulation, but we were going to do a layer of silver radiant barrier, with vinyl flooring on top. Do you think that will work on top of the bare metal?
Also, when mounting items to the floor (sink, bed, etc,) should I be using stainless self tapping screws? Thanks for your expertise!
Old 09-14-2017, 11:24 AM   #9
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Why the choice for radiant barrier versus insulation? My understanding of radiant barrier is that it works well for sunshine or maybe something like a hot engine that's radiating heat but will do little to stop the flow of heat moving through something if it is not specifically radiant heat. Closed cell foam has a lot of benefits including making your vehicle quieter and even reducing some of the vibration.
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
adhesive, floor, glue, wood
