07-27-2011, 07:12 PM
Year: 1985
Coachwork: blue bird
Chassis: gm
Engine: 366
Rated Cap: 25
gm 366 threw a rod. need to replace the motor. suggestions?
i just bought a 1985 gm short bus with a blue bird body. it has a blown motor. i knew this going in on the deal and thats why i got such a good deal on it. it currently has a gm 366 v8 big block in it. i would like to swap it out for something else. can i swap it out for a diesel? a bigger and better gm gas motor? any suggestions and help are appreciated. thanks!
07-27-2011, 07:43 PM
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Re: gm 366 threw a rod. need to replace the motor. suggestio
simple swap would be a 350 or bigger. dont want to go smaller!
07-27-2011, 08:11 PM
The GM366 is what they call a tall block..... Comes with a longer stroke over the regular engines plus they have 3 rings per cylinder instead of 2. Better compression, longer lasting etc....
GreyEagle
Roll - On...
07-27-2011, 09:07 PM
Chassis: International Amtran RE
Engine: DT466E/MD3060
I posted the same question in the mechanical section. I didnt blow mine but Im going to look for a short or long block to have on a stand and swap out at some point in time.
Things to consider.....
Does it have air brakes? If so most blocks that have air brakes are different from non air brake blocks. So that is #1 to consider.
Being a short bus you could get by with maybe a 350 depending on the gearing but I have a 66 passenger Ward so there is no way I could even think about it.
The 366 is in the 396/427 family of engines. azratrod is correct they are a tall block and they do have a set of extra rings in it and thats one reason why they do hold up if properly kept up. Really any chevy block will bolt up depending on issues as discusses above (air vs non air).
I stopped off at a bus barn here locally and asked input from them. They are a all diesel fleet but he has been in the business for 25+ years so he knows about gas engines. He suggested talking to Jasper engines? They seem to have a decent reputation in the bus world.
This engine came in many many many fleet trucks all the way till the 1990's I am told? So they are still out there.
As for going diesel I dont think there is a decent older chevy diesel out there worth putting in it. If you put a different maker.... well the adaptor thing comes in to play. Just depends on how much work you want to put in it.
Not sure what you will use it for but I am going back with the same that was in it. I wont use mine tons so just makes a in and out swap easy for me?
Hope this helps
07-27-2011, 10:44 PM
Is your bus already customized/converted? If not, it might be cheaper to buy a new bus with a good engine. Cost would be about the same as buying a new/rebuilt engine.
07-28-2011, 04:13 AM
Year: 1985
Chassis: gm
Engine: 366
Rated Cap: 25
the bus is slightly converted and has been painted. i knew about the motor being a dog and being blown up. i spoke with the fleet manager of the local chevy dealership and he said the dealership can take care of all of the maintanance on the bus due to it being all general motors products and equipment minus the blue bird body. the issue is getting a new motor into this old girl. ive looked on craigslist and have found a few nice 454 motors that have been rebuilt and even some that havent been rebuilt but have low milage. i think this might be the way to go.
07-28-2011, 09:17 AM
If you can get a replacement motor for a decent price then I agree, that's the way to go. Go with the 454.....you can never have too much power!
07-28-2011, 12:50 PM
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
look for a 454 rv motor,,there are build heavyer ,there not like a car motor,i got one an 545 just pull from an rv with 70,000 mile on . but iam north GA..so look for a big truck 454 not a car 454.trans would be a 400 auto....
keith
07-28-2011, 11:34 PM
Chassis: All-American R/E
366!
07-29-2011, 10:00 AM
being a short bus I dont know how many rpms you turn but my bus cracks about 3400-3800 @60-65 so its buzzing pretty high. I think a 454 (in stock form) will be tasked if it were in my bus? I had a TBI454 that I would consider putting in but I reconsidered and will go back with a 366 when that time comes.
I am sure there are gearing differences between our buses so you may be able to get by with it. If your going to keep the bus any time I would get the diesel? Theres a reason why fleets order then and gas units are usually not used?
I hope it all works out.
Bapos
07-30-2011, 02:22 PM
Year: 1985
Chassis: gm
Engine: 366
Rated Cap: 25
found a 454 out of a duelly truck with only 26,000 miles on the odometer. i heard it run and it sounds and runs great. he only wants $900 for it. i think im going to buy it and swap it into the shorty
07-30-2011, 03:36 PM
Really good price if its only 26,000 miles......
Good luck on the exchange ... May the Force be with you!!!!!!
GreyEagle
Roll - On...
07-30-2011, 06:26 PM
that is a good price. You should be able to get by with a shorty. Let us know how it works.
Not sure if its EFI or not but there are always alternitives
Bapos
07-30-2011, 07:43 PM
It wont be cheap but a Duramax diesel might be the ticket.
07-31-2011, 04:56 PM
Coachwork: Ward Genesis
Engine: DT466/MT643
You need to watch the RPM's...as has been said, many 366's are really buzzing due to deep gearing. Running a 454 for long periods at 3000+RPM will not do anything good for the engine!
Jarlaxle
08-04-2011, 05:02 AM
Year: 1985
Chassis: gm
Engine: 366
Rated Cap: 25
found a '90 chevy 366 with only 25,000 miles. i think this might be the best way to go
08-04-2011, 10:10 AM
of course this is just my opinion, but the chance of finding a 1990 engine with 25,000 miles are .00000001 percent. Be careful.
08-04-2011, 10:48 AM
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
might be best to just put that 366 in there lol.
but like mentioned, look her over with a fine tooth comb before you part with the cash lol
08-04-2011, 02:07 PM
I have not looked in to this on my 366 but is there a difference in blocks for units that have air brakes versus non air brake units? I have a guy with one on CL that he wants 300 bucks for it but I am holding off (not that I need one its just to have as a ready spare) till I know if there is a difference?
08-04-2011, 07:58 PM
Year: 1985
Chassis: gm
Engine: 366
Rated Cap: 25
the guy that has this 366 with 25,000 miles says the engine is perfect. its still in the 1990 kodiak/topkick 6500. i can still hear it run because its still in the truck. i asked about it running on the highway and pushing its rpms too high. he said the truck is happiest at 3000 to 4500 rpms
