Old 05-22-2014, 09:35 PM   #91
Re: Good deal for a bus?
http://www.skoolie.net/forum/viewtopic.php?f=9&t=12570
Here ya go..... Bansil can probably answer your questions
Malkieri is offline   Reply With Quote
Old 05-22-2014, 09:37 PM   #92
I was reading his thread when you posted this
jmar896 is offline   Reply With Quote
Old 05-22-2014, 09:48 PM   #93
opus's Avatar
Chassis: All-American R/E
It's probably got a low geared [high number] rear end. Which would limit top speed.
Old 05-22-2014, 11:33 PM   #94
Engine: 190hp 5.9 Cummins
Buy the bus.
Rear ends, and turbo's are changeable. No reason to miss out on owning a crown due to a few small details.
Old 05-23-2014, 09:48 AM   #95
How much do you think a higher geared rear end would run? I know it cost about 50 bucks when I switched the rear end on a golf cart. Also where is a good place to find one?
Originally Posted by nat_ster
Buy the bus.
I've been having trouble finding a new/rebuilt turbo online. Do the ones from the Dodge trucks with the 5.9 Cummins work?
Thanks
Jake
Old 05-23-2014, 10:18 AM   #96
opus's Avatar
From what I have read, you are talking $1000 for a rear end swap, fluid, seals, etc. Theres turbos all over Ebay, new, use, etc. I'm not positive on the Dodge aspect but I think they would be the same. Its the same engine but hp numbers might be different and such. Serial number off the engine would be the best bet.
Old 05-23-2014, 01:33 PM   #97
Chassis: TE2000 FE
Engine: 5.9L Cummins
Jake, go to your local Cummins dealer for rebuilt turbo. Ive found them to be the best source for part on the 5.9L bus engines.
Chuck
cschlessman is offline   Reply With Quote
Old 05-23-2014, 04:38 PM   #98
Im assuming its gonna cost another $500 or so for install, so this might not be the best bus.
Chuck
I just called 2 of the local dealers and bolth of them quoted between 500-600 for a rebuilt one or about 750-800 for a new one. Yikes.
So if I get the bus at 1650 (The current bid) plus 1250 for the new rear + $200 for used steer tires and if the turbos bad another 500. Plus the cost of driving it 1500 miles and airfair there. Its gonna put me pretty close to 4.5K and now my budget is 3K. Maybe I should wait and see...
Old 05-23-2014, 04:42 PM   #99
opus's Avatar
You can do better than that one. Find one directly from a school district, not an auction. This is the time of year they are taking buses out of service. Call local school bus shops and enquire. Get one that has records!
Old 05-23-2014, 06:38 PM   #100
Your going to let a Crown slip by because of a few bolt on parts?
Your looking in the wrong places for turbo's.
Get on the dodge diesel performance sites. A second gen dodge is the same engine.
This is a opportunity to upgrade the turbo for more power. No use in staying with the low power stock unit. Same with the rear end, this is a opportunity to upgrade for better highway speed.
good deal or no? bigballsbus Skoolie Conversion Projects 30 03-31-2008 03:29 PM
Good Deal? Bus(ted) Classifieds | Buy, Sell, Swap 8 12-03-2007 03:23 PM
Blood Bus - Good deal? or Let it go! Freedomhauler Conversion General Discussions 22 10-28-2007 08:22 PM
my new bus - did I get a good deal? LCD Everything Else | General Skoolie Discussions 5 09-27-2007 08:12 AM
Is this bus a good deal? KC10Chief Conversion General Discussions 7 07-01-2006 09:37 AM
