Old 11-02-2017, 07:27 AM   #1
spenceronehalf's Avatar
Coachwork: Never coached any teams, not even junior soccer
Chassis: I'm still figuring out what this means
Engine: CAT diesel
Rated Cap: No caps, only hats.
Gray Water Drip System
I'm contemplating putting in a gray "tank" that intentionally drips, percolating my gray water out on the ground ... slowly.
Obvious downsides could be clogged drip holes, icicles in winter, and soggy ground beneath the dripper over long term boondocking.
Any other thoughts pro or con?
Sent from my iPad using Tapatalk
spenceronehalf is offline   Reply With Quote
Old 11-02-2017, 11:19 AM   #2
Smell and potential tickets/fines.
I have had small grey water leaks and it was the smell that clued me in to the leak. It does smell. Especially in warm weather.
Old 11-02-2017, 12:23 PM   #3
...and as I know, illegal just about everywhere.
Old 11-02-2017, 12:45 PM   #4
Engine: CAT diesel
Illegal, smelly ... these are clearly concerns!
Still, I have an irresistible desire to make my bus drip.
Old 11-02-2017, 02:07 PM   #5
turf's Avatar
imo-
if you made a drip line coming out of your grey tank, you would end up concentrating the solids in your grey waste tank. it would not take long for that scum to get real foul and hard to clean out.
with the exception of your own property, you'd be risking a fine any time you "watered"
Turfmobile Build Thread
Old 11-02-2017, 09:15 PM   #6
Engine: CAT diesel
Yeah, a good drip system would likely have a filter you could periodically dump, an on/off valve for "non-drip mode," and then the dripper at a lowpoint in the holding system ...
