Old 12-20-2017, 11:00 AM   #1
CaseyBrown's Avatar
Chassis: TC 2000
Engine: C8.3 Cummins
Gross Weight Vs. Actual Weight For RV Title
Hello everybody,
Ok, my eyes are starting to cross searching for an answers on this.
I have a 38' Blue Bird TC/2000 with a gross vehicle weight of 36,500. DOT specifies that a CDL is not required if the vehicle weight does not exceed 26,000 even with air brakes (mine has air brakes). I realize this varies from state to state, but is valid in my home state of WA. It is my understanding that the GVWR is the maximum loaded weight (kids & equipment) based on the axle ratings, and not the empty weight.
Q1 When the finished conversion is weighed for inspection, does the new title reflect the actual weight, or is it the factory GVWR...in which case I'm hosed ?
Q2 Does anybody know what the stock empty weight of my '38 foot TC/2000 is?
My google foo isn't up to the task of getting a decent answer. I have seen everything from 17,000 to 24,000 suggested.
I'm at a real crossroad here. The real investment in time and money is starting in earnest this spring, and I need to know if I'm better off cutting bait.
Thanx in advance,
Casey
CaseyBrown is offline   Reply With Quote
Old 12-20-2017, 11:24 AM   #2
Coachwork: New Flyer
Chassis: D45HF "Viking"
Rated Cap: 51,600
The GVWR is the max load the bus chassis can carry. As long as you do not modify any part of the load-bearing frame or the suspension, the manufacturer's GVWR is what is recorded (at least it is in Indiana).
The driver of any vehicle that has a GVWR over 26k lbs., and that is driven for commercial purposes, must have a CDL - that's federal law. The actual limit is lower, but that's where the Fed Gov't has drawn the line in their regulations.
Now, look at that italicized part more closely. If you are not driving for commercial purposes, you do not need a federal driver's license (a.k.a. a CDL), as you do not fall under those Federal laws (only people engaged in commerce). However, your state may still have something to say about it - like an air brake endorsement on a "regular" DL - so you still need to do some investigation on what your state requires.
However, once you are legal in your "home" state, you are legal elsewhere in the U.S.A. by reciprocal agreements among the states.
There are also vehicle length limits. By-and-large interstates can handle up to 45' for a class B vehicle (like a bus) and 65' for an articulated vehicle (semis and other vehicles pulling trailers). However, some states like Colorado further limit vehicle lengths due to mountain passes and narrow mountain roads. Some roads also have height limits due to bridges and overpasses.
There are also weight limits on various roads (interstates vs. state highways vs. secondary roads) and bridges. In Indiana we also have "frost laws" that even further limit weight on certain roads during the winter (mainly secondary roads - to protect the roadbed during freeze/thaw cycles).
A good Trucker's map will give you all of the interstate and state highway restrictions. However, for secondary roads you are pretty much on your own (watch for signs!!). A Trucker's GPS device/service should give you all of the interstate and state highway restrictions, and be a bit hit-and-miss on the secondary roads.
MarkyDee is offline   Reply With Quote
Old 12-20-2017, 11:32 AM   #3
Robin97396's Avatar
If you're driving your bus around on a weekend, pull into a weigh station. The actual weight will show on the readout. It's not official, but it's accurate.
It's interesting to read the weight of the vehicle when it's all stripped out for the build.
Robin
Nobody's Business
Old 12-20-2017, 11:52 AM   #4
Rated Cap: 51,600
Once I have mine all stripped, this is exactly what I'm going to do. I think the CAT scales only charge about $8 or $10 for the weigh.
Old 12-20-2017, 12:16 PM   #5
Chassis: Saf-T-Liner MVP ER
This is a perfect answer.
One thing ... Only if you are driving commercially do you need to stop at the weigh centers at state lines.
However, if you are driving a bus that is bright yellow and covered in School Bus signage, etc, it is prudent to stop anyway.
Last thing you need is a state trooper chasing you down to ask why you failed to stop, and asking a bunch of awkward questions that he might not know the legal answers to.
When you pull into a weigh station, they simply direct you onto the weigh-bridge, and if your vehicle is not over weight you are good to go.
Steve Bracken
Build Thread
Old 12-20-2017, 12:26 PM   #6
CaseyBrown's Avatar
Chassis: TC 2000
Thanx for the replies guys,
I get so locked into relying on the inter-tubes for answers, I forget that sometimes the old school phone is a better option
After waiting about 10 minutes on "ignore" with WA state DOL, I have the answer to my first question. They base the title on actual weight from a state certified weigh station, not the GVWR...WOO-HOO .
As to my second question, actual weight, as mentioned above getting it weighed is the best option. However that isn't practical for me. I live in the sticks and had a family member with a class B CDL deliver it to me..I don't have one and can't legally drive it to the scales.
If anybody out there knows what 38 foot TC/2000 actually weighs PLEASE let me know.
Thank you everybody,
Casey
Old 12-20-2017, 12:29 PM   #7
Casey
Why can't you drive it yourself?
You will not be driving it commercially.
Steve Bracken
Build Thread
Old 12-20-2017, 01:14 PM   #8
CaseyBrown's Avatar
Chassis: TC 2000
Hi Twigg,
"Why can't you drive it yourself?
You will not be driving it commercially."
As I understand it (conversation with my insurance agent) until the title is changed to RV it is still considered a commercial vehicle whether it's being used as such or not . Obviously she could be wrong, but I would rather not have the debate with the state trooper manning the weigh station.
If I can't get an answer here or elsewhere online, I may take my chances and go that route.
Old 12-20-2017, 01:57 PM   #9
Hi Twigg,
It is considered a commercial vehicle, but insured for personal use. If you are bringing it home, law-enforcement won't even see it. School buses are invisible unless you do something dumb.
The weigh stations won't ask any questions, they will just weigh you and send you on your way. They don't come out, you don't go in unless requested to.
Steve Bracken
Build Thread
Old 12-20-2017, 02:10 PM   #10
CaseyBrown's Avatar
Chassis: TC 2000
Hi again Twigg,
Ok..Keep in mind this is Washington state, where no rule is to draconian or stupid. I just got off the phone with the Dept Of Licensing again and my fears were confirmed. Until the title is changed to RV, a CDL is required to drive it.
This leaves me in the absurd position of having to find a CDL driver to get me to the weigh station/inspection area to get title converted AND THEN I can drive it home
The weigh stations around my neck of the woods are manned by state troopers.
So I continue to beg the schoolie community for the weight of my empty bus
Old 12-20-2017, 02:13 PM   #11
MasterMerck's Avatar
Engine: 5.9L Cummins
36 foot 1999 All American FE
I have a fully converted 36 foot 1999 All American FE Bus. I weighed it at the local ag place. With the family in it, 21,940lbs. That poor 5.9L...
Nick
Nick Z.
MasterMerck is offline   Reply With Quote
Old 12-20-2017, 02:15 PM   #12
Hi again Twigg,
Most full-length, empty buses are under the 26000lb limit where CDL applies. Take out the seats and you lose another 2000 lbs.
Your bus, without seats, is likely to weigh between 18 and 22000 lbs empty.
Unfortunately, weighing it is the only way to be sure. If you have any contacts in your local school district, one of the bus drivers would probably help for $50.
Steve Bracken
Build Thread
Old 12-20-2017, 02:32 PM   #13
Rated Cap: 51,600
A lot of people get hung up on WHAT they are driving - "hey, this is a BIG vehicle, it must be a 'commercial' vehicle, therefore you must have a 'commercial' drivers license to 'drive' it!"
And, generally speaking, they'd be right, but not for the reasons they think.
The way the Federal CDL law is written, only IF you meet certain requirements does the law actually apply to you. Don't get me wrong, WHAT you are driving is important, but the law is written that WHY you are driving is paramount. WHAT you drive is subservient to WHY you drive.
It comes down to the "commerce clause" of the Constitution that gives the Federal Gov't the ability to "regulate commerce between the several states." (The poor clause has been tortured into covering a plethora of things the Feds have done that the Founding Fathers really didn't intend, but we won't go there right now.)
First, IANAL (I am not a lawyer). I am simply repeating here what others have said and history that you can research for yourself. Do not take what I am saying as legal advice. Please, please, go investigate for yourself.
Now that that is said, lets walk you through the history. Once you have seen this and research it yourself, you should make your own decision about it.
So, by the understanding of the "Commerce Clause", the Feds can regulate commerce between the states. However, they cannot regulate non-commercial activity between the states. (If the Federal Gov't tried to do this, then that law would stand a very good chance of loosing before the SCOTUS.)
The lawyers in D.C. have said that the CDL law gets its power from the "Commerce Clause" of the Constitution. Therefore, the CDL law cannot regulate non-commercial activity between the states. Since an RV is not deemed "commercial" (and, in fact, a vehicle titled as an RV is, by legal definition, "non-commercial"), the politicians specifically exempted the RV from CDL requirements.
Where things SEEM to get "murky" is when it comes to the class of vehicles commonly termed "commercial vehicles" (in our case, school and transit buses). Remember, the Fed can only regulate commerce (or commercial activity) between the states. So, if you are engaged in commercial activity in driving a vehicle between the states, you fall into their (Fed's) jurisdiction with regards to regulating commerce between the states (and, by extension, the CDL law / requirements).
So, driving a semi loaded with goods where you get paid for the job - that's easy - you have to have a CDL. Driving a bus load of people (ostensibly whom you are not related to) where you get paid for said job - easy, you have to have a CDL.
Ok, how about transporting your family or a few friends for fun? You aren't getting paid, so are you engaged in commerce? Nope. Why would that be different if you were in a "commercial vehicle" instead of a small car or SUV?
Old 12-20-2017, 03:24 PM   #14
This ^^^
Having taken care of the CDL requirements, you move on to investigating what YOUR state requires in terms of licensing. The state does not regulate the CDL, the feds do, so anything the state requires is on your state drivers license.
They may require:
Adding a Class of vehicle by weight
Adding an Air-brake endorsement
or ... none of the above ... like Oklahoma, even though I actually think they should!
If your state doesn't require additional licensing, then you are good to go in all 50 states.
Steve Bracken
Build Thread
Old 12-20-2017, 04:18 PM   #15
Rated Cap: 51,600
Originally Posted by Twigg View Post
This ^^^
They may require:
Thank you, Twigg, for the state requirements! I forgot to add that in and I appreciate you stating the obvious.
I do wish that Indiana had an air-brake endorsement for the standard operators license. I'd do that in a heartbeat for a number of reasons. One is that I just feel more comfortable with the fact I have air-brakes and they operate differently than my car's hydraulic brakes. Another is that I understand Canada requires an air-brake endorsement to drive an air-brake-equipped vehicle there (and I would sooo like to see some of Canada from my bus - maybe even drive all the way to Alaska...) - Canada is so close to Indiana....
Old 12-20-2017, 04:24 PM   #16
Traveling
Rated Cap: '00
2003 BB FE 35' mostly stripped except for Onan 10Kw Gen and sprayfoamed w/ roofraise.
Weight was 20,500- I bet I got another 800 lbs out of it since then, will have to weigh again.
Say 20K.
Old 12-20-2017, 04:29 PM   #17
Rated Cap: 51,600
Not bad!
10chars (what a silly thing to have to do).
Old 12-20-2017, 04:50 PM   #18
Reciprocity works in Canada too.
If you are legal in Indiana, you are legal in Canada.
Steve Bracken
Build Thread
Old 12-20-2017, 05:20 PM   #19
Rated Cap: 51,600
REALLY?!? Wonderful!
Old 12-20-2017, 05:28 PM   #20
I can't guarantee that every LEO in Canada understands that, but yes, the law is on your side.
Steve Bracken
Build Thread
