Old 12-05-2016, 10:37 AM   #1
Grouping batteries together for DC system?
I purchased new starting batteries. The ones i replaced are still good and they are 850 cranking amps. Can i add in a new 700 cranking amp battery as i collect my batteries for a system?
Old 12-05-2016, 02:59 PM   #2
Chassis: Blue Bird
Engine: ISC 8.3
"Kind of."
Electrically it'll work, it's not going to fry your devices, etc. But since you called the batteries out by "cranking amps" I'm assuming the old ones are also starting batteries, not deep cycle. If so their life will be short in house battery usage. They can be used, but you'd be needing to replace them sooner than you might expect. The biggest thing to extending their life (true of essentially all batteries, but especially so with lead starting batteries) is to limit the depth of discharge.
Old 12-05-2016, 10:00 PM   #3
AlleyCat67's Avatar
Year: 2005
Engine: Detroit MBE906
I agree with family wagon..... while you technically can use them, I would only do it for the short term, or as backup power.
You'd be a lot better off investing that money in deep cycle batteries, my personal preference is for 6v golf cart batteries since the amp hour rating is higher than you will find with 12v batteries. Granted you'll need more of them but the cost per amp hour will be less if you choose wisely.
I'll work up a cost per amp hour for some different batteries, then you can use that to choose something in your budget that will work.
EDIT: A Google Sheets workbook showing $/AH based off info found at batteriesplus.com. As of this edit it only has Duracell Ultra 6v and 12v batteries listed but that will be enough to show the cost difference between 6v and 12v.
One other thing... for the 6v the $/AH is calculated using TWO batteries in series to get 12v.
https://docs.google.com/spreadsheets...it?usp=sharing
Old 12-06-2016, 08:26 AM   #4
Thanks. I will be glad to look at it.
